Tutorial 16 - TeeChart's Additional palette components
Using the additional TeeChart Controls Selecting and inserting the component
Associating the component with a TChart
ButtonColor
ButtonPen
ChartListBox
Commander
Editor
GalleryPanel
TeeChart for.Net includes several additional controls that may be added to a project to enhance runtime functionality of a Charting application.
When you add the TeeChart for .Net Component to the Visual Studio .Net ToolBox, the additional controls are automatically added too.
You can associate the Commander and the other non-Chart components with a TChart by using the Chart property.
commander1.Chart = tChart1;
Commander1.Chart = TChart1
ButtonColor
ButtonColor shows a Color Editor and can be associated to the Color property of a TeeChart object to modify its color and transparency.
[C#]ButtonPen
private void Form1_Load(object sender, System.EventArgs e) {
line1.FillSampleValues(20);
colorBand1.Axis = tChart1.Axes.Left;
colorBand1.Start = line1.YValues.Maximum * 0.8;
colorBand1.End = line1.YValues.Minimum * 1.2;
buttonPen1.Pen = colorBand1.Pen;
private void buttonColor1_Click(object sender, System.EventArgs e) {
colorBand1.Color = buttonColor1.Color;
TChart1.Aspect.View3D = False
Line1.FillSampleValues(20)
ColorBand1.Axis = TChart1.Axes.Left
ColorBand1.Start = Line1.YValues.Maximum * 0.8
ColorBand1.End = Line1.YValues.Minimum * 1.2
ButtonPen1.Pen = ColorBand1.Pen
Private Sub ButtonColor1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles ButtonColor1.Click
ColorBand1.Color = ButtonColor1.Color
ButtonPen shows a Border Editor and can be associated to the Pen property of a TeeChart object to modify its visibility, color, ending, dash-style, width, style and transparency.
TeeListBox
ChartListBox shows a list of Series in the Chart at runtime. The ChartListBox may be used to offer the user limited customisation and display/hide of Chart Series.
Commander
The Commander bar allows navigation and parameter change control (via the TeeChart Editor) to be offered to users at runtime. Select the navigation buttons and with the left mouse button depressed, drag over the Chart panel to move the Chart.
Editor
The Editor allows the TeeChart Editor to be customised:
editor1.Chart = tChart1;
private void button1_Click(object sender, System.EventArgs e) {
editor1.DefaultTab = Steema.TeeChart.Editors.ChartEditorTabs.Legend;
editor1.Title = "My Application Title";
editor1.ShowModal();
Editor1.Chart = TChart1
Editor1.DefaultTab = Steema.TeeChart.Editors.ChartEditorTabs.Legend
Editor1.Title = "My Application Title"
Editor1.ShowModal()
GalleryPanel
The GalleryPanel shows a customisable Gallery of TeeChart Series.
