how can i adjust width of the bar with respect to each serie
Aravind
Post by Aravind » Mon Sep 11, 2006 4:17 pm
How can i adjust the width of the bar with respect to each series and each bar
i want to have different bar widths in each series in each y value
i want to have different bar widths for each series in each y value
for example
i have 3 series ,a b & c in a bar graph
for a barwidth is kept 40
for b bar width is 30
for c bar width is 100
barwidth option changes for all values of y axis , i need to different bar widths for different y values
pls advise me
aravind
Aravind
i have posted sample tee file
Post by Aravind » Mon Sep 11, 2006 4:23 pm
i have posted sample tee file in group
Post by Narcís » Tue Sep 12, 2006 8:45 am
Hi Aravind,
Have you tried setting the BarWidthPercent for each of the series? For example:
    TChart1.Series(0).asBar.BarWidthPercent = 70
Aravind
bar width for in a series
Post by Aravind » Tue Sep 12, 2006 12:58 pm
enclosing a bar graph with 3 bars drawn in it ( posted in newsgroup)
for example :
x values are 10 ,950,1350
bar plotted at x=10 should have size corresponding to its value
bar plotted at 950 should have 90% size ...
how to set differenct bar sizes in a series .....
thx
aravind
Post by Narcís » Tue Sep 12, 2006 2:53 pm
Hi Aravind,
Ok, now I understand what you are looking for. Then you can try doing something like this:
Private Sub Form_Load()
    Me.TeeCommander1.Chart = Me.TChart1
    TChart1.Import.LoadFromFile "e:\temp\samplebargraph.tee"
    TChart1.Environment.InternalRepaint
End Sub
Private Sub TChart1_OnBeforeDrawSeries()
    With TChart1.Series(0)
        For i = 0 To .Count - 1
            .asBar.BarWidth = (.XValues.Value(i) / .XValues.Maximum) * 100
        Next
    End With
End Sub
Aravind
Post by Aravind » Wed Sep 13, 2006 1:29 pm
bar width is changing but i have to insert my own calculations for bar width
if insert the below code , bar widths are not changing ..
Select Case i
Case 0
.asBar.BarWidth = 15
Case 1
.asBar.BarWidth = 35
Case 2
.asBar.BarWidth = 50
End Select
' .asBar.BarWidth = (.XValues.Value(i) / .XValues.Maximum) * 100
Next
End With
Post by Pep » Mon Sep 18, 2006 8:30 am
Hi Aravind,
I'm afraid there's no way to do this in the latest TeeChart Pro version, however it's on our wish list to be considered for the next releases.
In meantime a trick could be to use more than one Bar Series, each one with the desired barWidth.
Aravind
can you give sample code to draw the trick
Post by Aravind » Thu Sep 21, 2006 11:46 am
Post by Pep » Mon Sep 25, 2006 10:37 am
you can do :
With TChart1
    .AddSeries scBar
    .AddSeries scBar
    .AddSeries scBar
    .Series(0).Color = vbRed
    .Series(1).Color = vbRed
    .Series(2).Color = vbRed
    .Series(0).AddXY 0, 10, "", clTeeColor
    .Series(1).AddXY 1, 20, "", clTeeColor
    .Series(2).AddXY 2, 30, "", clTeeColor
    .Series(0).asBar.MultiBar = mbSideAll
    .Series(0).asBar.BarWidth = 15
    .Series(1).asBar.BarWidth = 35
    .Series(2).asBar.BarWidth = 50
    .Legend.LegendStyle = lsLastValues
End With
End Sub
Aravind
Post by Aravind » Mon Sep 25, 2006 11:33 am
i need to set the widths of the first x value
for x=1 barwidth=10
for x=2 barwidth=30
for x=3 barwidth=100
not with respect to series
this is nothing but a carpetchart calculations ....
Post by Narcís » Mon Sep 25, 2006 1:47 pm
Hi Aravind,
You should create one bar series for each X value, SelfStack the series and set a different BarWidth for each of them:
    For X = 0 To 3
        TChart1.AddSeries scBar
        TChart1.Series(X).asBar.MultiBar = mbSelfStack
        TChart1.Series(X).asBar.BarWidth = 15 + (15 * X)
        TChart1.Series(X).ColorEachPoint = True
        TChart1.Series(X).Marks.Visible = False
        For Y = 0 To 10
            TChart1.Series(X).AddXY X, Rnd, "", clTeeColor
        Next Y
    Next X
End Sub
Aravind
still having problems with barwidth for mulitple series
Post by Aravind » Thu Sep 28, 2006 11:58 am
i have enclosed a sample chart in xls file need to draw this chart ..
in the x-axis i have plotted a.b.c with 5 series ...
i need to have for a bar width for all 5 series should be 77.7
for b it is 16.8 and for c it should be 5.4 ( i.e. for a i should give 70% width , b 16 % width and c 5% width) but now i can create equal bar width in tchart ...
the sample code which is given by you does not suite my requirement ... because values are not been plotted correctly and also coloring each series becomes a issue ... if i set color for series entire bar becomes same color which is not correct for us because for bar @a there is 5 series plotted ...
your code :
For X = 0 To 1
For Y = 0 To 2
TChart1.Series(X).AddXY X, Y, Y, clTeeColor
Next Y
Next X
need code to adjust barwidth for each position at x-axis ...
Post by Narcís » Thu Sep 28, 2006 2:44 pm
Hi Aravind,
I have posted an example at the newsgroups which creates a chart similar to your excel file.
Aravind
I Cannot able to find it could you pls send me to this email
Post by Aravind » Thu Sep 28, 2006 2:48 pm
I Cannot able to find it could you pls send me to this email asreenivasan@dtc-worldwide.com
Post by Narcís » Thu Sep 28, 2006 2:50 pm
Hi Aravind,
Yes, just forwarded the message to your address.
