Issue on Loading MACD Function from Binary File
Petar
Post by Petar » Thu Dec 16, 2010 3:06 pm
I have an assignment issue when I load a set of charts containing the function MACD.
For example, if I draw a chart with MACD function and Stochastic function, i will have normally :
Axtchart.series (0).title = Title1
Axtchart.series (1).title = TitleMACD
Axtchart.series (2).title = Nothing
Axtchart.series (3).title = Nothing
Axtchart.series (4).title = TitleStochastic
But if I load these series from a file, I have the following assignments :
Axtchart.series (2).title = TitleStochastic
Axtchart.series (4).title = Nothing
Re: Issue on Loading MACD Function from Binary File
Post by Yeray » Fri Dec 17, 2010 4:36 pm
Hi Petar,
I think that this would be because the MACD function creates 2 internal extra series that aren't exported to the file and when the file is loaded it probably loads the series in the file and once this has been made, the MADC extra series are created.
You could try changing the order of the series with ExchangeSeries method once the file has been loaded.
