Labels issue with 2 series
Petar
Post by Petar » Tue Dec 07, 2010 3:28 pm
I would like to chart 2 series with .XValues.DateTime = False . 1st one charted on form load and 2nd one on button click.
2nd serie is larger then 1st serie. In this case I have the issue listed below.
Example code
Option Explicit
Private Sub Command1_Click()
        TChart1.AddSeries (scFastLine)
        TChart1.Series(1).asFastLine.TreatNulls = tnSkip
        TChart1.Series(1).XValues.DateTime = False
        Dim i As Integer
        Dim value As Double
        value = 45
        For i = 1 To 720
            value = value + 0.03 * (Math.Rnd() - Math.Rnd())
            TChart1.Series(1).AddXY i, value, Format(Now - 720 + i, "dd/mm/yy"), clTeeColor
        Next i
End Sub
    Private Sub Form_Load()
        TChart1.Aspect.View3D = False
        TChart1.Axis.Bottom.Labels.DateTimeFormat = "dd/mm/yy"
        TChart1.Series(0).asFastLine.TreatNulls = tnSkip
        TChart1.Series(0).XValues.DateTime = False
        Dim i As Integer
        Dim value As Double
        value = 45
        For i = 300 To 720
            TChart1.Series(0).AddXY i, value, Format(Now - 365 + i, "dd/mm/yy"), clTeeColor
        Next i
    End Sub
Have you any idea how can I correct this.
Re: Labels issue with 2 series
Post by Yeray » Thu Dec 09, 2010 3:48 pm
Hi Petar,
I think this is the same problem that was identified here.
So when TV52015179 will be fixed in VCL, it should become fixed in ActiveX too because TeeChart AX is a wrapper from TeeChart VCL.
Petar
Post by Petar » Fri Dec 10, 2010 9:22 am
in fact that seems to be the same problem, but issue was reported 1month and half ago, do you have any idea, when it should be fixed?
Petar
Post by Yeray » Fri Dec 10, 2010 2:25 pm
Hi Petar,
I'm afraid not. As Narcís said in the link above,
Narcís wrote:This is a high-priority issue in the defect list but hasn't been fixed yet. At this stage I can't commit to a release date. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's fixed on them.
But we could be near to a solution as you can see here
guilz2010
Post by guilz2010 » Mon Dec 13, 2010 8:01 am
Hi Steema Support Team,
This issue is Very Critical for us (and our clients) - Could you please fix it and release it quickly ?
Thanks a lot
Guilz
Post by Yeray » Wed Dec 15, 2010 10:45 am
Hi Guilz,
We understand it and that's why we've given high priority to it. Please, stay tuned.
Post by Narcís » Mon Jan 17, 2011 3:42 pm
Hello everyone,
Just wanted to let you know that TV52015179 has been fixed for the next maintenance release.
guilz2010
Post by guilz2010 » Mon Nov 07, 2011 12:54 pm
with Teechart v2011 we still have this bug
As you can see, we have 2 series (1 as fast line - Serie1, 1 as Gantt - Serie 2) the issue is that Gantt label are displayed on the bottom axis and we can't see the date labels of serie 1
We do not want to view Gantt labels on bottom axis but we want view them on Gantt chart (Months FEB11, MAR11, APR11, MAY11, JUN11 must be displayed on gantt chart but not on bottom axis where there is already date labels of serie 1
Thank you for your help
Guilz
Post by Yeray » Tue Nov 08, 2011 12:14 pm
I've verified with v2010.0.0.1 this reproduced the problem but not now with v2011.0.0.4:
  Dim i, j As Integer
  Dim cxdate As Date
  For i = 0 To 1
    TChart1.AddSeries scFastLine
    cxdate = Date
    For j = 0 To 49
      TChart1.Series(i).Add Rnd(100), FormatDateTime(cxdate), clTeeColor
      cxdate = cxdate + 31
    Next j
  Next i
End Sub
However, the code from Petar, in the beginning of this thread still reproduces the overlapping problem:
  Dim i As Integer
  Dim value As Double
  value = 45
  For i = 300 To 720
  Next i
  value = 45
  For i = 1 To 720
  Next i
End Sub
So this could be an slightly different problem than TV52015179.
I've opened a new VCL bug ticket with the code above translated to Delphi, that reproduces the problem for me here with the actual sources (TV52015820).
Excuse us for the confusion generated.
