Installing v5 after Installing .NET TeeChart
chipshot
Post by chipshot » Fri Jul 30, 2004 2:04 pm
Please help,
I am new to the team (and to TeeCharts). We are building a .NET and installed TeeCharts for .NET no problem.
I just found out I have to go back and do some maintenance on a site that has TeeCharts v5 on it. I tried to install v5 on my local machine and am having problems viewing the charts from the old site.
If I comment out the following line in the old asp code, I can view the chart but only in 3D (originally it was 2D):
Chart1.Aspect.View3D = False
If I uncomment that line and pull up the page I get a blank graph and an error that states: "Wrong *.tee file format"
Please help with any suggestions:
Should I have installed v5 then .NET versions?
Post by Pep » Fri Jul 30, 2004 2:35 pm
Strange, you're the first person with this problem. Make sure you've only one TeeChart Pro ActiveX version registered and also try to uninstall all the versions (not the NET version) and install the ActiveX again.
Could you please post and example into the steema.public.attachments newsgroup so I can reproduce the problem here ?
This should not be a problem.
chipshot
How do I get to that newsgroup I don't see it!?!
Post by chipshot » Fri Jul 30, 2004 3:20 pm
Thanks!
chipshot
Post by chipshot » Fri Jul 30, 2004 3:21 pm
How do I get to this newsgroup? I don't see it under newsgroups.... thanks!
Post by Narcís » Fri Jul 30, 2004 3:30 pm
use a newsreader and the following url:
[url=news://www.berneda.com]news://www.berneda.com[/url]
chipshot
Post by chipshot » Fri Jul 30, 2004 3:47 pm
Our company will not allow us to download or post to newsgroups, shot you an email with the example
Post by Pep » Fri Jul 30, 2004 5:27 pm
you can send me it directly to my account : pep@steema.com
