TeeChart 8 hanging under Windows 2008 R2 Terminal Server
insoftware
Post by insoftware » Tue Nov 30, 2010 12:54 pm
We are using TeeChart ActiveX in our Visual C++ application for years but recently our customers starter reporting a weird issue: when our application is run in Terminal Server session on Windows 2008 Server R2 and customer tries to open a dialog with embedded TeeChart, whole application hangs.
Issue was first reported with TeeChart 5. Recently, we have updated TeeChart to version 8 (8.00.0.8 exactly) and the problem still appears.
After our investigation we have found that hanging happens during TeeChart control initialization. It seems that TeeChart tries to enumerate available printers and it hangs during enumeration. Here is appropriate stack walk information:
  ntdll.dll!_KiFastSystemCallRet@0()
  ntdll.dll!_NtWaitForSingleObject@12()  + 0xc bytes
  kernel32.dll!_WaitForSingleObjectEx@12()  + 0x84 bytes
  kernel32.dll!_WaitForSingleObject@8()  + 0x12 bytes
  tsprint.dll!CRIMStreamProxy::CMessageEntry::Wait()  + 0x14 bytes
  tsprint.dll!CRIMStreamProxy::ReceiveMessage()  + 0x121 bytes
  tsprint.dll!CMessage::CommitReceive()  + 0x18 bytes
  tsprint.dll!CProxyITS_PrintDriver<ITS_PrintDriver>::InitializePrinter()  + 0xab bytes
  tsprint.dll!CTSCacheEntry::Initialize()  + 0x2a3 bytes
  tsprint.dll!CTSPrinterCache::GetDriverProxy()  + 0x1a0 bytes
  tsprint.dll!GetCachedDriverProxy()  + 0x17 bytes
  tsprint.dll!CallClientSideDocumentProperties()  + 0x80 bytes
  tsprint.dll!SpoolerCallingDocumentPropertySheets()  + 0x27 bytes
  tsprint.dll!_DrvDocumentPropertySheets@8()  + 0x4b bytes
  winspool.drv!_DocumentPropertySheets@8()  + 0x142 bytes
  winspool.drv!DocumentPropertiesWNative()  + 0xeb bytes
  winspool.drv!_DocumentPropertiesA@24()  + 0x40 bytes
> TEECHART8.OCX!042ae191()
  [Frames below may be incorrect and/or missing, no symbols loaded for TEECHART8.OCX]
  winspool.drv!_RpcEnumPrinters@28()  + 0x1a bytes
  winspool.drv!_EnumPrintersW@28()  + 0xa5 bytes
  03228058()
  TEECHART8.OCX!04279aba()
  TEECHART8.OCX!042ae8d8()
  ntdll.dll!@RtlpFreeHeap@16()  + 0x335 bytes
  ntdll.dll!_RtlFreeHeap@12()  + 0xed5 bytes
  kernel32.dll!_BaseDllReadVariableValue@16()  + 0x1a2 bytes
Please note that TeeChart8.ocx has loaded at different address:
 TEECHART8.OCX C:\Windows\System32\TEECHART8.OCX N/A N/A Binary was not built with debug information.  71 8.00.0.8 6/19/1992 11:22 PM 04270000-048C8000* Waa.DMP: Native
We have also found that:
- printing from Windows application works properly at the time when TeeChart hangs (tested with our application and Notepad)
- disabling local printer redirection when connecting to Terminal Server solves the problem (i.e. TeeChart no longer hangs during initialisation), however this solution is not acceptable for our customers - they need printing using local printers.
Can you please solve the problem with TeeChart?
Mariusz Wojcieszek
IN-Software.com LP
Re: TeeChart 8 hanging under Windows 2008 R2 Terminal Server
Post by Sandra » Fri Dec 03, 2010 9:50 am
Hello Mariusz,
Excuse us for the delay. We haven't forgotten you. We'll be back to you asap.
insoftware
Post by insoftware » Mon Dec 20, 2010 2:29 pm
Any progress on this issue? Our customers are waiting for solution.
Mariusz Wojcieszek
IN-Software.com LP
Post by Sandra » Wed Dec 22, 2010 3:28 pm
Hello insoftware,
I inform that you can find in costumer page a new release of TeeChartActivex in English where the problem of hang is solved. Please download it and check if now your TeeChartActivex is installed as expected.
