GDI+ : a border around bars in Bar chart is always visible.
ESRI
Post by ESRI » Fri Feb 25, 2011 1:06 am
Border around bars in Bar chart is always visible in GDI+ mode. To repro:
1) create bar chart
2) start Tee Editor and turn off border visibility for bars. Borders disappear.
3) turn on GDI+ mode. Borders are back. I can change border style, color and I see changes while "Visibility" check-box is unchecked.
Actually, there are more borders appear around the graph in GDI+ mode. Bars in Bar chart is the simplest case.
Alex.
Re: GDI+ : a border around bars in Bar chart is always visible.
Post by Yeray » Fri Feb 25, 2011 9:46 am
Hi Alex,
In v8.07, in GDI+ you could hide the BarPen as follows:
uses Series, TeeGDIPlus;
    FillSampleValues();
    BarPen.Visible:=false;
  Chart1.Canvas:=TGDIPlusCanvas.Create;
However, in v2010, the following code doesn't hide the BarPen.
A workaround is to make the BarPen.Style to bsClear, but it's not exactly the same:
    FillSampleValues();
    //BarPen.Style:=psClear;  //workaround not perfect
  with TTeeGDIPlus.Create(self) do
    TeePanel:=Chart1;
    Active:=true;
So I've added it to the defect list to be revised for future releases (TV52015417).
