I am having difficulty sizing my charts. The chart seems to have a display size that it uses regardless of what size I set the control to. Also, when I resize the chart, it will sometimes not display at all, and I cannot figure out a way to get the chart to display again. What am I doing wrong? It seems to work in your Access example. In fact, that is currently what I am doing. I size the chart in your demo and copy it into my project. If I then try to modify the size farther, it fails.
Brad
Cannot resize control. Control goes blank.
- TeeChart.zip
- Chart now fails to display entirely
- (95.02 KiB) Downloaded 639 times
Re: Cannot resize control. Control goes blank.
Hello Brad,
I can reproduce your problem using your project, but when I have modified your project, changing the control of Activex8 you have added for my control Activex8, seems that problems is solved and chart appears. Please, can you try if next project works as you expected and your problem is solved? I hope will helps,
| Sandra Pazos / Development & Support Steema Software Avinguda Montilivi 33, 17003 Girona, Catalonia Tel: 34 972 218 797 http://www.steema.com |
Hello Sandra,Sandra wrote:I can reproduce your problem using your project, but when I have modified your project, changing the control of Activex8 you have added for my control Activex8, seems that problems is solved and chart appears. Please, can you try if next project works as you expected and your problem is solved?,
Using your project, I am still able to replicate the problem.
Brad
Hello Brad,
We are working to try to find a solution for this problem and we have inform you asap.
Hello Brad,
Please, take a look in my replay in thread and check again if your problem appears using new OCX.
