Some settings not saved in TChart 2011.
TonyVSUK
Post by TonyVSUK » Wed Feb 22, 2012 11:42 am
The "Visible" setting the gradient on "walls" is not being saved.
To reproduce,
1. Display the graph editing dialog.
2. Click the "Walls" tab.
3. Click the "Back" tab.
4. Click the "Gradient" button.
5. Click "Visible".
6. Save the graph to a stream
7. Load from a stream. The "Visible" is now ticked again.
I store my TCharts with the following code
COleVariant tStream = pTChart->GetExport().GetAsNative().SaveToStream(TRUE);
// attach the stream to SafeArray
COleSafeArray safeArray;
safeArray.Attach(tStream);
and then load using
m_PropGraph.pTChart->GetImport().LoadFromStream(*m_pGraphContentsStream);
Tony.
Re: Some settings not saved in TChart 2011.
Post by Yeray » Fri Feb 24, 2012 5:03 pm
Hi Tony,
I'm trying to reproduce it in VB6 but it seems to work fine. Here it is the code I used:
  TChart1.Walls.Back.Visible = False
  TChart1.AddSeries scLine
  TChart1.Series(0).FillSampleValues
  tmpStream = TChart1.Export.asNative.SaveToStream(True)
  TChart1.ClearChart
  TChart1.Import.LoadFromStream tmpStream
After importing the chart, I can't see the back wall. I've also tried giving it another color to see it clearer:
  TChart1.Walls.Back.Color = vbRed
  TChart1.Walls.Back.Gradient.Visible = False
  TChart1.Walls.Back.Visible = False ' commenting/uncommenting this line makes the difference, as expected
  TChart1.ClearChart
  TChart1.Import.LoadFromStream Stream
If you still have problems with it, please try to arrange a simple example project we can run as-is to reproduce the problem here.
Also please tell us what exact TeeChart version are you using.
TonyVSUK
Post by TonyVSUK » Fri Feb 24, 2012 5:15 pm
      TChart1.ClearChart
This will not recreate the problem will it?
What happens if you do something like try and load to a different chart?
      TChart2.ClearChart
      TChart2.Import.LoadFromStream tmpStream
Post by Yeray » Tue Feb 28, 2012 3:38 pm
With that code I get two charts looking the same (with TeeChart v2011.0.0.5):
TonyVSUK
Post by TonyVSUK » Fri Jun 08, 2012 8:43 am
Try this. Create two charts, one is initialised with a red background and some sample values. Then copy to a new chart via SaveToStream/LoadFromStream. The panel settings are not saved.
Private Sub UserForm_Initialize()
UserForm1.TChart1.Panel.Color = RGB(255, 0, 0)
UserForm1.TChart1.Panel.Gradient.Visible = False
End Sub
Private Sub CopyChart1ToChart2_Click()
Dim stream
stream = TChart1.Export.asNative.SaveToStream(True)
TChart2.Import.LoadFromStream stream
End Sub
Post by Yeray » Fri Jun 08, 2012 3:10 pm
Right, it seems the Gradient.Visible property isn't restored correctly. I've added it to the defect list to be revised (TA05016218).
TonyVSUK
Post by TonyVSUK » Fri Jun 08, 2012 3:12 pm
Is there a workaround for now?
Post by Yeray » Fri Jun 08, 2012 3:42 pm
Hi Tony,
The only workaround I see is to manually save&restore the gradient.visible property into a variable.
TonyVSUK
Post by TonyVSUK » Fri Jun 08, 2012 5:05 pm
Is the gradient the only thing that is not stored?
Post by Yeray » Mon Jun 11, 2012 11:41 am
Hi Tony,
The gradient is the only thing we've identified that isn't been correctly exported/imported.
We haven't verified all the TeeChart properties. So, if anybody finds a property not being exported/imported, don't hesitate to let us know.
TonyVSUK
Post by TonyVSUK » Tue Jun 12, 2012 12:27 pm
It seems as if the following is not saved either
UserForm1.TChart1.Walls.Back.Transparent = True
Post by Yeray » Tue Jun 12, 2012 2:26 pm
Hi Tony,
You are right. I've added it to the TA05016218 description.
Thanks for reporting it.
Post by Marc » Fri Jun 22, 2012 3:06 pm
These issues can't be reproduced with the latest release version. Serialization appears to be working correctly for these cases. The registered issue will be closed unless new information to the contrary comes to light.
