Multiple colors on a line Serie
Ced
Post by Ced » Thu Dec 11, 2003 8:38 am
Hello!
I have a line serie in a red color. I want now a portion of this line to be green.
I tried with SetColorEachPoint and SetPointColor but this doesn't work.
Any idea?
Post by Marc » Thu Dec 11, 2003 9:10 am
The following syntax should work ok:
m_Chart1.Series(1).SetPointColor(2,RGB(0,255,0));
You mention you've tried SetPointColor without success, perhaps there's a different issue. I've tested this with a LineSeries. Please check the syntax and let us know if the problem still isn't cleared up.
Ced
Post by Ced » Thu Dec 11, 2003 9:18 am
I used exactly the same syntax (except that the serie was stored in a member variable of my class).
In fact, my line serie contains a lot of points (something like 2000 points). So, is the color just used on the POINTS or also on the line between the points ??? I need of course the second solution (I want a portion of my line to be displayed in green)
Thanks for quick response :D
Post by Marc » Thu Dec 11, 2003 9:41 am
The codeline (SetPointColor) modifies the Line colour itself and the Point colour for a LineSeries.
I've double-checked that with TeeChart AX v5 and v6.
Please check that you are not using a FastLineSeries as that Seriestype doesn't support individual colour setting for points (or line segments).
Ced
Post by Ced » Thu Dec 11, 2003 10:04 am
:oops: Oooooopss, sorry ! That was it ;-)
Ok, I changed it into a normal line and now that works fine :-)
