Problem with axis label font color
Hi All
I wanna create a graph with the left axis in Orange color, but the graph is generated with the left axis in black color.
This is part of my code
w_AxeYvalue = wMinimunY1
With Grafico.TChart1.Axis.Left.Labels
.Clear
.Font.Color = RGB(255, 128, 64)
For i = 1 To 6
.Add w_AxeYvalue, Format$(w_AxeYvalue, "###,##0")
w_AxeYvalue = w_AxeYvalue + wStepY1
Next i
End With
What is missing?
Best regards
.Clear
For i = 1 To 6
Next i
End With
What is missing?
Best regards
- Graph
- IGBVL_DowJones.jpg (88.4 KiB) Viewed 21120 times
Re: Problem with axis label font color
Hi Daniel,
You can change axis and axis labels color like this:
TChart1.Axis.Left.AxisPen.Color = vbYellow
TChart1.Axis.Left.Labels.Font.Color = vbYellow
Hi Narcís
Yes, I wrote this in my code
Grafico.TChart1.Axis.Left.Labels.Font.Color = RGB(255, 128, 64)
But the axis label is print in black Color (like the attach image)
What is missing?
Best regards
What is missing?
Best regards
Hello Daniel,
The exact sintaxis for the color setup depends on the environment you use.
Hi Yeray
With the Narcís's suggest
TChart1.Axis.Left.AxisPen.Color = RGB(255, 128, 64)
Only the Axis lines is changed, but not the text label
I'm ussing VB6, and Windows 7
- Graph
- IGBVL_DowJones.jpg (88.44 KiB) Viewed 21038 times
What exact TeeChart version are you using?
It works fine for me here with v2013.0.1.0 and also with v2012.0.0.9:
Private Sub Form_Load()
TChart1.Header.Text.Text = TChart1.Version
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
TChart1.Series(0).FillSampleValues
TChart1.Series(0).Color = RGB(255, 128, 64)
End Sub
Hi Yeray
This is my version
TeeChart Pro v8.0.0.7.09908
Best regards
This is my version
Best regards
- Version
- TeeChartHelp.jpg (53.86 KiB) Viewed 20995 times
We must be doing something different. This is what I get in a simple project with just a chart on the form and the code above, with TeeChart ActiveX v8.0.0.7: Please, try to arrange a simple example project we can run as-is to reproduce the problem here.
Hi Yeray
Please try this
The left labels titles are in black color, only the left's axis line is orange, and I need the titles in orange
Thanks a lot
Please try this
Thanks a lot
TChart1.Axis.Left.SetMinMax 0, 1000
TChart1.Axis.Left.Increment = 200
With TChart1.Axis.Left.Labels
.Clear
.Font.Color = vbGreen 'RGB(255, 128, 64)
For i = 0 To 1000 Step 200
.Add i, Format$(i, "###,##0")
Next i
End With
End Sub
- Grafico
- TeeChartHelp.jpg (54.19 KiB) Viewed 20985 times
Hi Daniel,
Ah, I see the font formatting didn't work fine when using custom labels in TeeChart ActiveX v8. It works fine from TeeChart ActiveX v2010.0.0.1.
Ok Yeray
Best regards
Best regards
Hi Yeray
I have a question
Which version still works fine with visual basic 6.0?
This is for update my current version, because I need graphing the axis with a custom color
I have a question
Hi Daniel,
The latest version still supports VB6. Give it a try at the evaluation version to see if it fits your requirements.
http://www.steema.com/download/ax
