I have a line chart. I set the Title for YAxis. But the title is not positioned correctly. It is not at the start, center or end and it is cut.
The text should be "transactions / sec".
See attachment.
TeeChart2014 OCX - Line Chart - YAxis - Title
- YAxisLabelNotPositionedCorrectly.jpg (27.55 KiB) Viewed 17357 times
Re: TeeChart2014 OCX - Line Chart - YAxis - Title
The text looks to be too long for the chart height.
I'd suggest you to set a smaller font size.
Alternatively, I'd suggest you to try with an Annotation tool instead of using the Axis Title.
This is how it looked with TeeChart2012.ocx. The same text and the positioning was correct.
- LineChart_LabelPoistioning_2012.PNG (9.03 KiB) Viewed 17270 times
I can't reproduce the problem with the actual version and this code:
I may be missing some relevant property to reproduce the problem.
Can you reproduce the problem switching GDIPlus for GDI?
If you still find problems with it, could you please arrange a simple example project we can run as-is to reproduce the problem here?
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
TChart1.Series(0).Add 50000, "", clTeeColor
TChart1.Series(0).Add 0, "", clTeeColor
TChart1.Axis.Left.Title.Caption = "transactions / sec"
The problem occurred when exporting and the size is 363 x 105.
I will try to make a demo.
Anyway, I see the difference appeared in TeeChart VCL v2013.09 (note TeeChart ActiveX is a wrapper form TeeChart VCL).
I'll add this to the public tracker to be revised for future releases.
http://bugs.teechart.net/show_bug.cgi?id=825
In the meanwhile, the only workaround I can think on wound be using an Annotation tool instead of the Left Axis Title. Ie:
First note the two images you've posted have a different size. One is 373x115 and the other is, as you said, 363x105.Micro wrote:The problem occurred when exporting and the size is 363 x 105.
TChart1.Header.Clear
'TChart1.Axis.Left.Title.Caption = "transactions / sec"
TChart1.Panel.MarginLeft = 5
TChart1.Tools.Add tcAnnotate
With TChart1.Tools.Items(0).asAnnotation
.Text = "transactions / sec"
.Shape.Angle = 90
.Shape.Transparent = True
.Shape.CustomPosition = True
.Shape.Left = -30
.Shape.Top = 45
End With
TChart1.Aspect.GDIPlus.Active = False
TChart1.Environment.InternalRepaint
TChart1.Export.asBMP.Width = 363
TChart1.Export.asBMP.Height = 105
TChart1.Export.asBMP.SaveToFile "C:\\tmp\\testAXbmp.bmp"
When can be expected for this fix to be available?
I can't say that. I'd suggest you to add your mail to the CC list to be automatically notified when an update arrives.
