RemoveSeries does not release memory allocated to series
jhameenniemi
RemoveSeries does not release the memory allocated to the removed series. Included is a test application which removes an old bar series from chart and creates a new bar series to chart every 100 ms using a timer. If you open up TaskManager in Windows you'll see that the private bytes allocated for the test application increases rapidly and never decreases i.e. memory is never released.
- TeeTest.zip
- (87.71 KiB) Downloaded 1065 times
Re: RemoveSeries does not release memory allocated to series
I've reproduced this and created a new ticket in the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=938
