Positioning Custom Vertical Axes
Posted: Tue Mar 31, 2015 8:37 pm
by 9532498
I'm using TChart ActiveX version 7.
Trying to write code to position several vertical custom axes to the right of the chart. The number of these custom axes that will be added will be determined at runtime.
Following the general guidelines outlined in the link below:
http://stackoverflow.com/questions/1469 ... s-creation
However, using the code above, my axes are placed too close together and often an axis is superimposed on top of the title of the previous custom axes.
How do I find the size of the spacing in pixels to properly place a Custom Axis so that the following have been taken into account for the previous custom axis?
1) Length of tickmarks
2) Length of Labels
3) Separation between Labels and Title
4) Length of Title (angled at 90 degrees) to Axis so as to run along axis.
Re: Positioning Custom Vertical Axes
Posted: Wed Apr 01, 2015 10:49 am
Here it is an example in VB6 considering TickLength, Labels.MaxWidth, the space between Labels and Title (extraPos) and Title length (both horizontal and vertical):
Private Sub Form_Load()
TChart1.Aspect.View3D = False
TChart1.Legend.CheckBoxes = True
TChart1.Header.Visible = False
TChart1.Legend.Alignment = laBottom
TChart1.Panel.Color = RGB(192, 192, 192)
Dim nSeries As Integer
Dim i As Integer
Dim vAxis As Integer
nSeries = 5
For i = 0 To nSeries - 1
TChart1.AddSeries scLine
TChart1.Series(i).FillSampleValues 25
vAxis = TChart1.Axis.AddCustom(False)
With TChart1.Axis.Custom(vAxis)
.AxisPen.Color = TChart1.Series(i).Color
.GridPen.Visible = False
If i > 2 Then
.Otherside = True
End If
.Title.Caption = "Axis Title " + Str$(i)
.Title.Angle = 90
.Title.Font.Color = TChart1.Series(i).Color
End With
TChart1.Series(i).VerticalAxisCustom = vAxis
TChart1.Axis.Custom(vAxis).PositionUnits = puPixels
Next i
TChart1.Panel.MarginUnits = muPixels
TChart1.Environment.InternalRepaint
End Sub
Private Sub PlaceAxis(ByVal nSeries As Integer, ByVal NextXLeft As Integer, ByVal NextXRight As Integer, ByVal MarginLeft As Integer, ByVal MarginRight As Integer)
Const extraPos As Integer = 5
'Variable
Dim MaxLabelsWidth As Integer
Dim lenghtTicks As Integer
Dim titleMargin As Integer
Dim margin As Integer
If TChart1.Series(nSeries).Active Then
MaxLabelsWidth = TChart1.Axis.Custom(nSeries).Labels.MaxWidth
lenghtTicks = TChart1.Axis.Custom(nSeries).TickLength
If TChart1.Axis.Custom(nSeries).Title.Angle = 90 Then
titleMargin = TChart1.Canvas.TextHeight(TChart1.Axis.Custom(nSeries).Title.Caption)
Else
titleMargin = TChart1.Canvas.TextWidth(TChart1.Axis.Custom(nSeries).Title.Caption)
End If
margin = MaxLabelsWidth + lenghtTicks + titleMargin + extraPos
If TChart1.Axis.Custom(nSeries).Otherside Then
TChart1.Axis.Custom(nSeries).PositionPercent = NextXRight
NextXRight = NextXRight - margin
MarginRight = MarginRight + margin
Else
TChart1.Axis.Custom(nSeries).PositionPercent = NextXLeft
NextXLeft = NextXLeft - margin
MarginLeft = MarginLeft + margin
End If
TChart1.Panel.MarginLeft = MarginLeft
TChart1.Panel.MarginRight = MarginRight
End If
nSeries = nSeries + 1
If (nSeries <= TChart1.SeriesCount - 1) Then
PlaceAxis nSeries, NextXLeft, NextXRight, MarginLeft, MarginRight
End If
End Sub
PlaceAxis 0, 0, 0, 5, 5
End Sub
Private Sub TChart1_OnClickLegend(ByVal Button As TeeChart.EMouseButton, ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
End Sub
Posted: Wed Apr 01, 2015 3:55 pm
by 9532498
Thanks. That worked for the most part.
I am using TChart ActiveX Pro Version 7. How do I get the width in pixels of the largest label for the axis? Labels.MaxWidth gives me the same number for each of my axes even though the labels are different in width. i.e. some have more decimal places in them than others. When the labels are long (more decimal places) the title for the custom axis seems to overlap the labels and or the next custom axis. So something somewhere in the calculation is not quite adding up.
Posted: Thu Apr 02, 2015 11:40 am
I've modified the code in the post above with a couple of small fixes.
This is what I get with TeeChart ActiveX v7.0.1.4:
- default.png (27.16 KiB) Viewed 20465 times
If I scroll the chart a bit to see a longer label for the yellow axis, I see the margin on the left gets bigger to fit the new:
- scrolled.png (22.86 KiB) Viewed 20456 times
Debugging I could also see the difference. MaxLabelsWidth for nSeries=2 is 21 without scrolling and 30 when the "1.000" label is shown.
Posted: Fri Jul 24, 2015 11:27 pm
by 16673658
Is there a reason to call PlaceAxis from the OnAfterDraw() method?
Posted: Mon Jul 27, 2015 7:21 am
by narcis
Hi nbp,
That's to allow the chart to draw all elements so properties used in that method have been initialized and have valid values.
