Building TChart Classes into .lib
nbp
Post by nbp » Thu Jun 18, 2015 8:36 pm
I am using TChart Pro ActiveX 2015. I want to build a .lib with all the TChart 2015 .cpp and .h files.
Then in my application which is dll I want to link statically with the .lib.
In Visual Studio 2010, what type of new project should I create if I want the COM support (COleDispatchDriver etc.)?
The plan is to link statically with the .lib and then use the provided ocx component (TChart2015.ocx) at runtime.
nbp
Re: Building TChart Classes into .lib
Post by nbp » Thu Jun 18, 2015 9:03 pm
I want to add that currently I build the TChart classes into my application (dll) but I want to avoid that by building a .lib and linking with that.
Post by Marc » Fri Jun 19, 2015 10:51 am
It looks as if the best way to achieve what you want is to ...
create a Win32 project, and in the Application Settings on the next page, choose ....
(http://stackoverflow.com/questions/5840 ... n-visual-c)
It seems that here you would select the 'Static library' option. I tried that and it appears to work ok to create a project with .lib output.
I hope that may be of help.
nbp
Post by nbp » Fri Jun 19, 2015 10:04 pm
Thanks. I tried that and it worked.
