Hi, Yeray,
I am a newbie in Teechart Map series. I learned the examples provided with the installed AX (Tchart7.ocx) how to load the ESRI shp with the tchart Map series in VB6, and the example code you provided can load only the polygon file. Could you provide more codes in VB6 for adding the line and point shp files?
Looking forward to receiving your support.
VB6 code for loading the ESRI line and point shp file
Re: VB6 code for loading the ESRI line and point shp file
Could you please send us some shp files with lines and points we could use to test it?
Thanks Yeray for your reply. What I meant is a polylines shp file. I learned in your VB sample source code, it mentioned case polyline but did not provide codes for it.
Best regards
Best regards
Do you have one we can use to test it?SPR wrote:What I meant is a polylines shp file
Dear Yeray
Please find attached the zip file, which comprises of 3 files: shp; shx and dbf.
Best regards
Sopharith
Best regards
Sopharith
- mainstream.zip
- (87.77 KiB) Downloaded 1087 times
Dear Yeray,
I would like to send you the new file in Latlong (degree). The recent sent is in UTM in metres.
Best regards,
Best regards,
- mainstreams_LL.zip
- (83.37 KiB) Downloaded 1073 times
We are adding a new method to Map Series to load the map directly from filename. The method will be available with the next update, ready within the next few days.
Thanks Marc. Looking forward to receiving the update.
Best regards,
Sopharith
Best regards,
Sopharith
