MaxVisibleSeriesValue and MinVisibleSeriesValue function
nefis
Post by nefis » Thu Dec 18, 2003 11:40 am
the functions apparently returns min\max for all points, not for those being currently visible in chart
Post by Marc » Thu Dec 18, 2003 1:23 pm
I can't reproduce that here. Please could you confirm results with the following code:
- Place 1 TChart, 1 ChartPageNavigator and 2 Labels on a Form and paste in this code:
Private Sub Form_Load()
ChartPageNavigator1.Chart = TChart1
TChart1.Page.MaxPointsPerPage = 15
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
TChart1.Series(0).Marks.Visible = True
TChart1.Series(0).FillSampleValues 225
End Sub
Label1.Caption = TChart1.Series(0).MaxVisibleValue(1)
Label2.Caption = TChart1.Series(0).MinVisibleValue(1)
End Sub
The Labels should match up with the highest and lowest values of the Marks.
Post by Marc » Thu Dec 18, 2003 1:26 pm
As a followup... I mistook the methods you had tested, but the result here is the same with the equivalent Axes methods:
  Label1.Caption = TChart1.Axis.Left.MaxVisibleSeriesValue(True, 0)
  Label2.Caption = TChart1.Axis.Left.MinVisibleSeriesValue(True, 0)
End Sub
nefis
Post by nefis » Thu Dec 18, 2003 2:40 pm
hello Marc,
let's changit in the way i use it in my app and the results are totaly different:
  TChart1.Series(0).FillSampleValues 1000
  TChart1.Axis.Bottom.Automatic = False
  TChart1.Axis.Bottom.Maximum = 1000
  TChart1.Axis.Bottom.Minimum = 900
End Sub
  Label1.Caption = "MinVisibleSeriesValue: " & TChart1.Series(0).MinVisibleValue(1)
  Label2.Caption = "MaxVisibleSeriesValue: " & TChart1.Series(0).MaxVisibleValue(1)
End Sub
nefis
Post by nefis » Fri Dec 19, 2003 11:46 am
still waiting...
nefis
Post by nefis » Sun Dec 21, 2003 2:55 pm
still waiting...
nefis
Post by nefis » Mon Dec 22, 2003 2:37 pm
still waiting...
nefis
Post by nefis » Tue Dec 23, 2003 12:10 pm
still waiting...
Post by Marc » Tue Dec 23, 2003 4:22 pm
Your code seems to work ok here. It tells me the correct Max Y value and Min Y value on the visible Chart. If I zoom-in or drag-scroll the result updates itself accordingly, correctly.
I can't explain what might be happening in your Chart. The code is straightforward and there is little room for ambiguity unless you are running it alongside other factors not mentioned in your post. Let us know if there are any other clues in your particular setup.
Steema Support:
Please note that Steema do not commit to reply to support posts except on Pro-support forums. Whilst we endeavour to reply to as many requests for help as possible, you may experience delays or 'non-reply' on this forum. I'd also like to take the opportunity to express that we welcome any participation/response from other customers to help overall inertia.
With thanks.
