Polygon disappears when read from tee file
waterboy
Post by waterboy » Thu Jan 08, 2004 2:27 pm
I have TeeChart Pro ActiveX v 6.0.0.4.
I have written a simple ASP/VBScript using scMap. It writes both a tee file and a jpg file using identical data. When I display both files on same page in Internet Explorer, the jpg file is fine, but the tee file shows only the axes and background - no polygon!?
Any ideas?
waterboy
Issue tracker entry 1309
Post by waterboy » Fri Jan 09, 2004 2:23 pm
I see that this problem has been entered into the Issue Tracker system on 9/22/2003 as issue 1309, but it doesn't look like anything has been done. Am I interpreting what I am seeing correctly?
Scott Beddingfield
US Geological Survey
Post by Pep » Mon Jan 12, 2004 10:08 am
Hi Scott,
yes, it's on our defect list. We'll try to fix it for the next maintenance releases of TeeChart.
Josep Lluis Jorge
http://support.steema.com
