Show in TeeListBox
ACC
Show in TeeListBox
Post by ACC » Mon Apr 23, 2007 3:19 pm
Hi
Simple question, exists a property or method that allows hide or show a serie in the TeeListBox as ShowInLegend property of ISeries ??
Post by Yeray » Tue Apr 24, 2007 9:38 am
Hi ACC,
There's no method to show/hide series individually from a TeeListBox yet but you can assign a group to the TeeListBox. So you can create your custom group and the TeeListBox will only show the series you wish.
At the following example I use ComboBoxes to select the series to show. But note that in each ComboBox I delete and create again the SeriesGroup:
Private Sub Check1_Click()
  TChart1.SeriesList.Groups.Delete 0
  TChart1.SeriesList.AddGroup "Group 0"
  If Check1.Value Then
    TChart1.SeriesList.Groups.Items(0).Add 0
  End If
  If Check2.Value Then
    TChart1.SeriesList.Groups.Items(0).Add 1
  End If
  TeeListBox1.SeriesGroup = TChart1.SeriesList.Groups.Items(0)
  TeeListBox1.UpdateSeries
End Sub
Private Sub Check2_Click()
  End If
  End If
End Sub
Private Sub Form_Load()
  TChart1.AddSeries scBar
  TChart1.Series(0).FillSampleValues
  TChart1.Series(1).FillSampleValues
  'you should set the ComboBoxes to Checked by default
  TeeListBox1.Chart = TChart1
End Sub
Post by Yeray » Tue Apr 24, 2007 11:16 am
And I can announce the new property "Items" for TeeListBoxes, available for the next release v8. So you will be able to do:
TeeListBox1.Items.Remove (0)
ACC
Post by ACC » Tue Apr 24, 2007 7:59 pm
Thank you very much.
Saludos
