Tee Chart as Thumb Nail
Areef
Post by Areef » Mon May 21, 2007 6:55 am
I want to display the Tee Chart which I am already exporting as PNG Image as Thumb Nail version. Can some one tell me how can I do so?
Areef
Post by Narcís » Mon May 21, 2007 8:11 am
Hi Areef,
When exporting a chart to an image you can specify the size of the image you want to generate, for example:
    TChart1.Export.asPNG.Height = 20
    TChart1.Export.asPNG.Width = 50
Areef
Post by Areef » Mon May 21, 2007 8:42 am
Hi Narcís,
It does NOT help me. My Tee Chart is best viewed at 720*360 (Width*Hieght) size. Now, I want the same Image to be available in smaller size of say 50*20. if I change the Width and Height as suggested by you here, the Image is LOST and only some portion of the Image is shown.
Thanks and Regards,
Areef
Post by Narcís » Mon May 21, 2007 8:48 am
Hi Areef,
Then you could save the chart's size in temporary variables, resize it to 50*20, export the chart and resize the chart again to the original dimensions.
Areef
Post by Areef » Mon May 21, 2007 8:58 am
I think I did't get exactly what you wanted me to do.
My code is as follows.
tchart.Export.asPNG.Width = 720;
tchart.Export.asPNG.Height = 360;
return ((byte[]) tchart.Export.asPNG.SaveToStream());
I want this same code to be running in 2 modes, one mode while exporting as Full Image and another mode to export as Thumb Nail basically a smaller view of the same Image.
Could you help me in re-arranging the code so that I achieve my task?
Thanks again and Regards,
Areef
Post by Narcís » Mon May 21, 2007 9:08 am
Hi Areef,
My suggestion was something like this:
    Dim tmpW, tmpH As Integer
    tmpW = TChart1.Width
    tmpH = TChart1.Height
    'Export chart
    TChart1.Export.asPNG.SaveToFile FileName
    'Export thumbnail
    TChart1.Width = 50
    TChart1.Height = 20
    TChart1.Export.asPNG.SaveToFile ThumbnailName
    'Restore original chart dimensions
    TChart1.Width = tmpW
    TChart1.Height = tmpH
Areef
Post by Areef » Mon May 21, 2007 9:21 am
When I am exporting in one style/mode I am not worried about the other style/mode.
When I am in Full Image Modei will export as Full Image only and not worried about Thumb Nail version and similarly when I am in Thumb Nail mode, I will export as Thumb Nail only and dont bother to resize back to normail Image mode.
So, my code snippet would be like this.
If (ExportAsFullImage)
else if (ExportAsThumbNail)
   tchart.Export.asPNG.Width = 70;
   tchart.Export.asPNG.Height = 60;
If you observe here, I am not deling here with File Names at all and am exporting to stream and this stream is written to screen. I tried with this code only and when I am exporting as Thumbnail, the Image gets clipped rather than showing as a small Image.
I was wondering does the Zoom or CompressionLevel properties help me in any way?
Areef
Post by Narcís » Mon May 21, 2007 9:31 am
Hi Areef,
Please notice that the code I posted actually resizes the chart, not the exported image. Could you please try if it works fine at your end?
Areef
Post by Areef » Mon May 21, 2007 9:46 am
I tried with the code as follows:
          tchart.Width = 70;
          tchart.Height = 60;
But, again here also the same result of clipping of the Image. is it correct what I am doing here?
Areef
Post by Pep » Thu May 31, 2007 4:03 pm
Hi Areef,
yes, one way to accomplish it, as you said, would be using the Zoom. You will have to change the Zoom before to do the export :
TChart1.Aspect.Zoom = 150
or assign it to 100 depending on the choosed option.
