"Stream read error" using TChart1.Import.LoadFromF
Post by » Mon Dec 01, 2003 2:58 pm
When I use an annotation in a *.tee file and this annotation contains an accent (french : &eacute, è etc.) I get the "Stream read error" while loading the *.tee using TChart1.Import.LoadFromFile...
If I remove the accent, it works. The problem occured with version 5.06 of the english and multi-language versions of the ActiveX.
Looks like a bug to me. I tried loading the binary *.tee file into a variant then using LoadFromStream on it but it didn't work either.
Frederick Samson
Post by Pep » Tue Dec 02, 2003 12:05 am
Hi Frederick,
yes, you are correct, this bug has been solved in the TeeChart Pro AX v6.
Josep Lluis Jorge
http://support.steema.com
Post by » Tue Dec 02, 2003 2:18 pm
Will it be solved in TeeChart 5.07 ?
Frederick Samson
Post by Pep » Fri Dec 12, 2003 12:36 am
There is currently no further maintenance release planned for TeeChart AX v5. However the issue you have reported has been solved in the TeeChart Pro v6.
Josep Lluis Jorge
