Native Export in XML format?
hugh
Post by hugh » Tue Apr 08, 2008 4:15 am
I need to export native chart properties in XML format - as demonstrated in the Export Dialog - any idea how to do that?
Hugh
Post by Yeray » Tue Apr 08, 2008 8:05 am
Hi Hugh,
I'm afraid it's not possible to save chart properties into an xml file. If you want to save them, you'll have to save into a tee file.
You can have a look at the detailed explanation in the tutorials:
Tutorials/Chapter 12 - Exporting and Importing Charts
And at the examples from features demo:
All Features/Exporting/Chart Data/XML
All Features/Exporting/Native binary format/Templates
Both tutorial and demos should be available at TeeChart's program group.
hugh
Post by hugh » Tue Apr 08, 2008 9:20 am
that's what I also found - however - how it is done in the Export Dialog - there I can export in Text and XML???
Post by Narcís » Tue Apr 08, 2008 9:27 am
Hi hugh,
Text and XML only allows exporting chart data. You'll find an example at Tutorial 12 - Exporting and Importing Charts, "Exporting data" section replacing asHTML for asText or asXML.
Examples can also be found here:
http://www.teechart.net/support/viewtop ... ght=astext
http://www.teechart.net/support/viewtop ... ight=asxml
Hope this helps!
hugh
Post by hugh » Tue Apr 08, 2008 9:51 am
Narcis,
I did study all the lessons you are telling me - just to make sure we are on the same page and understand my question, please....
Open the Editing Window -> Export -> Tab: Native
this lets u:
a) select 'Include Series data'
b) select a 'Format': Binary
Text
XML
with the option to view Text and XML - and this data is the config for the chart...
c) the File size
so - it is possible in the editing tool...
thanks,
Hugh[/img]
Post by Narcís » Thu Apr 10, 2008 9:06 am
Hi Hugh,
Yes, we forgot to include these method (SaveToXMLFile and SaveToXMLStream) at runtime. We have just added them for the next maintenance release. In the meantime, if it's necessary, we can send you the .ocx with this feature.
hugh
Post by hugh » Fri Apr 11, 2008 1:43 am
Narcis,
Great - I would apprecciate if you could send me the ocx.
Thanks, Hugh
Post by Narcís » Mon Apr 14, 2008 10:37 am
Hi Hugh,
I've just sent you the new .ocx. Please remember that you'll need to unregister current version and register new one as I told on this thread.
hugh
Post by hugh » Mon Apr 14, 2008 12:47 pm
Gottit,
Hugh
hugh
Export XML Native
Post by hugh » Mon Apr 14, 2008 10:26 pm
Hi Narcis,
I did uninstall the old ocx - and installed the new ocx as described - but annot see any difference in functionality - even the version number remained 8.0.0.3 - it is possibe u just sent me the old version again??
Otherwise please explain how to export native into XML format - thanks
Hugh
Post by Narcís » Thu Apr 17, 2008 11:31 am
Hi Hugh,
Yes, you are right. I've sent you now the correct ocx. You should use it like this:
    TChart1.Export.SaveToXMLFile FileName
