TeeChart doesn't working with Chinese characters
CEIC
Post by CEIC » Tue Dec 11, 2007 6:49 pm
we are working with TeeChart for Java version 1, Build 1.0.1.818 and have problem for generate image (jpg format) with Chinese characters for labels. It is support for this version?
Post by Marc » Wed Dec 12, 2007 3:25 pm
Chinese characters are supported. The following test checks out ok here:
chart.getSeries(1).getMarks().setVisible(true);
chart.getSeries(1).add(3,"序列");
chart.getSeries(1).add(6,"序列");
chart.getSeries(1).add(7,"序列");
chart.getHeader().setText("序列");
If your project does not support unicode you may use \u character coding: eg. "\u5E8F\u5217"
What option to use may depend on the environment you are using. Use the UTF8 file project option if available in your programming environment.
