Workaround for Error in area charts w/stairs w/origin
Miguel
Post by Miguel » Fri Feb 18, 2011 1:11 pm
Hello
Some weeks ago I found a bug and reported to TeeCharts, they are working on it but I need a workaround, the problem is as follows: If you create an area chart with stairs and set the origin on the max value (to see it up side down) the chart doesn't shows fine.
What could be a workaround for this problem? I need an upside down stairs chart, or something like it
Thanks in advance :)
Re: Workaround for Error in area charts w/stairs w/origin
Post by Yeray » Mon Feb 21, 2011 3:14 pm
Hi Miguel,
You could use a Bar3D serie sinstead of using an Area series with stairs:
    private void initChart() {
        com.steema.teechart.styles.Area area1 = new com.steema.teechart.styles.Area(tChart1.getChart());
        area1.fillSampleValues();
        area1.setUseOrigin(false);
        area1.setOrigin(area1.getMinYValue() + Math.round((area1.getMaxYValue() - area1.getMinYValue()) / 2));
        area1.setUseOrigin(true);
        area1.setStairs(true);
        com.steema.teechart.styles.Bar3D bar1 = new com.steema.teechart.styles.Bar3D(tChart1.getChart());
        bar1.setDataSource(area1);
        bar1.getMarks().setVisible(false);
        bar1.setBarWidthPercent(100);
        for (int i=0; i<bar1.getCount(); i++)
            bar1.getOffsetValues().setValue(i, area1.getOrigin());
        area1.setActive(false);
        tChart1.getAxes().getLeft().setMinMax(bar1.getYValues().getMinimum() - tChart1.getAxes().getLeft().getMinimumOffset(), bar1.getYValues().getMaximum() + tChart1.getAxes().getLeft().getMaximumOffset());
Miguel
Post by Miguel » Fri Feb 25, 2011 6:54 pm
Hi Yeray, I have a problem with this solution, when I zoom horizontally the first (most left) Bar doesn't show up, do you know how to fix that?
Thanks for the workaround though
Post by Yeray » Mon Feb 28, 2011 3:36 pm
Hi Miguel,
I've seen that, if you scroll a chart with a Bar series, each bar disappears when half bar is out of the bar (only in the left side of the chart). I've added it to the wish list to be enhanced in future releases (TJ71015425).
To reproduce it you only need a Bar series and scroll a little bit:
        com.steema.teechart.styles.Bar bar1 = new com.steema.teechart.styles.Bar(tChart1.getChart());
        bar1.fillSampleValues(6);
could you please confirm if this is what you are experiencing?
Miguel
Post by Miguel » Mon Feb 28, 2011 9:07 pm
Hello Yeray
Yes, that's what I'm experiencing :)
My problem is that I can't wait for a future release :( Is there another way to get an up side down stairs area chart? or to add the feature myself by editing the source code? maybe regarding the bug TJ71015368 (the source of all of the conversation :)
Thanks again!
Post by Yeray » Tue Mar 01, 2011 4:12 pm
Hi Miguel,
In the meanwhile, a workaround could be to draw manually the hidden portion of the bar:
        tChart1.addChartPaintListener(new ChartPaintListener() {
            @Override
            public void axesPainting(ChartDrawEvent e) {
            @Override
            public void chartPainted(ChartDrawEvent e) {
                for(int i=0;i<bar1.getCount()-1;i++)
                    int right = bar1.calcXPos(i+1);
                    if (tChart1.getAxes().getBottom().getMinimum()>bar1.getXValues().getValue(i) && (right > tChart1.getChart().getChartRect().getLeft()))
                        tChart1.getGraphics3D().getBrush().setColor(bar1.getColor());
                        tChart1.getGraphics3D().getPen().setColor(bar1.getPen().getColor());
                        int left = tChart1.getChart().getChartRect().getLeft();
                        int top = Math.max(bar1.calcYPos(i), tChart1.getChart().getChartRect().getTop());
                        int bottom = tChart1.getAxes().getLeft().calcPosValue(bar1.getOffsetValues().getValue(0));
                        tChart1.getGraphics3D().rectangle(left, top, right, bottom);
                        break;
            @Override
            public void chartPainting(ChartDrawEvent e) {
            @Override
            public void seriesPainting(ChartDrawEvent e) {
            @Override
            public void seriesPainted(ChartDrawEvent e) {
The code above works for a Bar Series with BarWidhPercent = 100.
Miguel
Post by Miguel » Tue Mar 01, 2011 9:39 pm
Hi Yeray, the last code doesn't work for me (maybe because I'm using Bar3D) :(
Do you know where, on the source code, can I deactivate the default 'half out bar disappearance' ?
Post by Yeray » Wed Mar 02, 2011 11:14 am
Hi Miguel,
The workaround proposed works for me in the example I posted some posts above.
The complete example would be this:
    com.steema.teechart.styles.Bar3D bar1;
            @Override
            @Override
                        break;
            @Override
            @Override
            @Override
If you still have problems with it don't hesitate to let us know.
Miguel
Post by Miguel » Wed Mar 02, 2011 1:01 pm
Hi Yeray, I implemented the code with another series plotted (as I have several on my project) and the result is the attachment, it doesn't work for me :( the fisrt left bar doesn't show up
Example
Sin título.png (18.75 KiB) Viewed 32163 times
Miguel
Post by Miguel » Wed Mar 02, 2011 2:08 pm
Yeray, the rectangle shows up when I keep the mouse pressed down on the plot :s that's weird
Miguel
Post by Miguel » Wed Mar 02, 2011 9:52 pm
Any ideas for get this to work? :?
Post by Yeray » Thu Mar 03, 2011 4:11 pm
Hi Miguel,
I've only set the Brush and the Pen color to draw the bar portions manually. Assigning the whole bar brush could fix the problem.
Change the following in the example above:
                        tChart1.getGraphics3D().setBrush(bar1.getBrush());
                        //tChart1.getGraphics3D().getBrush().setColor(bar1.getColor());
                        //tChart1.getGraphics3D().getPen().setColor(bar1.getPen().getColor());
Post by Marc » Thu Apr 14, 2011 10:27 am
This issue, id TJ71015368, is resolved for inclusion in the next maintenance release.
The problem does not occur in SWT but does occur in Swing although the same underlying graphics calls/libraries are used.
If you wish to apply the fix pending receipt of the maintenance release this is the required modification:
In TeeChart's Graphics3DAWT.java unit, replace the following line:
   * Draws a Rectangle (Rectangle r).
   * @param r Rectangle
  public void rectangle(Rectangle r) {
with
  private Rectangle invertNegativeRect(Rectangle r)
      if (r.width < 0)
          int tmpL=r.getLeft();
          r.setLeft(r.getRight());
          r.setRight(tmpL);
      if (r.height < 0)
          int tmpT=r.getTop();
          r.setTop(r.getBottom());
          r.setBottom(tmpT);
      return r;
    r=invertNegativeRect(r);  //TJ71015368
