non-GMT DateTimes offset
Saman
Post by Saman » Wed May 21, 2014 9:18 am
When you use DateTime as chart X axis, the graph is not align properly. It always shifts to right.
Can you please check and let me know how to get this right.
this is the code i used
@Override
	protected void onCreate(Bundle savedInstanceState) {
		super.onCreate(savedInstanceState);
		setContentView(R.layout.activity_main);
		LinearLayout group = (LinearLayout) findViewById(R.id.teeChart);
		chart = new TChart(this);
		group.addView(chart);
		chart.getPanel().setBorderRound(7);
		//common graph settings
		chart.getLegend().setAlignment(LegendAlignment.BOTTOM);
		chart.getLegend().setLegendStyle(LegendStyle.SERIES);
		chart.getLegend().getFont().setSize(20);
		chart.getHeader().getFont().setSize(25);
		chart.getAxes().getLeft().getTitle().getFont().setSize(15);
		chart.getAxes().getLeft().getLabels().getFont().setSize(15);
		chart.getAxes().getBottom().getLabels().getFont().setSize(15);
		ThemesList.applyTheme(chart.getChart(), 1);
		try
			series = Series.createNewSeries(chart.getChart(), Line.class, null);
			series.getXValues().setDateTime(true);
			series.add(new DateTime(2014, 05, 16), 5);
			series.add(new DateTime(2014, 05, 17), 8);
			series.add(new DateTime(2014, 05, 18), 3);
			series.add(new DateTime(2014, 05, 19), 4);
			series.add(new DateTime(2014, 05, 20), 0);
			series.getMarks().setArrowLength(0);
			series.getMarks().getFont().setSize(15);
			chart.getAxes().getBottom().getLabels().setDateTimeFormat("dd MMM");
			chart.getAxes().getBottom().setIncrement(Utils.getDateTimeStep(DateTimeStep.ONEDAY));
		catch (Exception e)
			e.printStackTrace();
Saman
Re: TeeChart Java/Java for Android v3.2014.0519 update
Post by Yeray » Wed May 21, 2014 11:11 am
Hello Saman,
This is how it looks for me. How does it look for you?
Saman
Post by Saman » Wed May 21, 2014 11:32 am
This is what I get (also please note that I am in UK different time zone)
I have attached the photo
Saman
Post by Yeray » Wed May 21, 2014 12:22 pm
Hello Saman,
This sounds similar to this:
http://bugs.teechart.net/show_bug.cgi?id=420
Could you please show us how do you set your layout?
If you are sharing the LinearLayout for texts and the chart, can you please try using an independent LinearLayout without margins for the Chart?
Saman
Post by Saman » Wed May 21, 2014 1:25 pm
Following is the code I use.
I changed the layout to only have chart as follows, but still the issue is there.
Layout activity_main.xml
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:paddingBottom="@dimen/activity_vertical_margin"
    android:paddingLeft="@dimen/activity_horizontal_margin"
    android:paddingRight="@dimen/activity_horizontal_margin"
    android:paddingTop="@dimen/activity_vertical_margin"
    tools:context=".Main" >
    <LinearLayout
        android:id="@+id/teeChart"
        android:layout_width="fill_parent"
        android:layout_height="fill_parent"
        android:orientation="vertical">
    </LinearLayout>
</RelativeLayout>
Activity class Main.java
public class Main extends Activity {
	private TChart chart;
	private Series series;
	@Override
		try
		catch (Exception e)
	@Override
	public boolean onCreateOptionsMenu(Menu menu) {
		// Inflate the menu; this adds items to the action bar if it is present.
		getMenuInflater().inflate(R.menu.main, menu);
		return true;
Hope this will help you to check the issue.
Saman
Saman
Post by Saman » Thu May 22, 2014 9:43 am
Hi Yeray
I found the isuue. Your DateTime only works for GMT time zone. so from the code we have to change the default time zone to GMT
following code worked.
DateTime dt = new DateTime(2014, 05, 16);
dt.setTimeZone(TimeZone.getTimeZone("GMT"));
series.add(dt, 5);
dt = new DateTime(2014, 05, 17);
series.add(dt, 8);
dt = new DateTime(2014, 05, 18);
series.add(dt, 3);
dt = new DateTime(2014, 05, 19);
series.add(dt, 4);
dt = new DateTime(2014, 05, 20);
series.add(dt, 0);
Thanks for your support.
Saman
Post by Yeray » Thu May 22, 2014 9:44 am
Hello Saman,
Great! Thanks for sharing the solution you found!
I've split the discussion into a new thread to keep the new release announcement clear
