Axis titles are displayed off screen when using an offset
WST
Post by WST » Wed May 21, 2014 8:12 pm
Setting a minimum or maximum offset on a vertical axis using setMinimumOffset() or setMaximumOffset() causes the axis title to be displayed off screen until the chart is re-sized to be larger. If the maximum and minimum offsets are removed the title is displayed as expected.
When this example is loaded "Left Axis" is usually not visible until the window is re-sized. If the maximum and minimum offsets are removed "Left Axis" is displayed as expected.
        Line line1 = new Line();
        line1.fillSampleValues();
        TChart chart = new TChart();
        chart.getAspect().setView3D( false );
        chart.addSeries( line1 );
        chart.getAxes().getLeft().getTitle().setText( "Left Axis" );
        chart.getAxes().getLeft().setMinimumOffset( 3 );
        chart.getAxes().getLeft().setMaximumOffset( 3 );
        JFrame f = new JFrame();
        f.add( chart );
        f.pack();
        f.setVisible( true );
Is there a workaround or bug fix for this?
Re: Axis titles are displayed off screen when using an offset
Post by Yeray » Fri May 23, 2014 7:52 am
Here is what I get in TeeChart Swing. Is this the environment you are using and what you are getting?
If this is not what you are observing, please try to arrange a simple example project we can run as-is to reproduce the problem here.
WST
Post by WST » Fri May 23, 2014 5:11 pm
Yes that is what I am seeing. Notice that the string "Left Axis" is partially off screen. Resizing the window smaller will have is disappear further off screen. This problem does not occur when not using setMaxiumOffset and setMinimumOffset.
Post by Yeray » Tue May 27, 2014 10:30 am
I reproduced the problem here, so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=782
And I've also found the fix for it. So the next maintenance release will include this fix.
WST
Post by WST » Tue May 27, 2014 6:21 pm
Thanks for the information. When will the next maintenance release be? Is there a workaround we can use for this issue now?
Post by Yeray » Wed May 28, 2014 8:23 am
WST wrote:When will the next maintenance release be?
I'm afraid I can't tell you a date for the next release to be published.
WST wrote:Is there a workaround we can use for this issue now?
I'm afraid I can't think on a workaround that achieves the same result, other than avoid using setMaxiumOffset.
However, I think you own the sources and, since the fix consists in a small change, you can apply the fix yourself.
In Axis.java, find a private method called maxLabelsValueWidth. Where it says:
        if ((isDateTime() && labels.getExactDateTime())
                || labels.getRoundFirstLabel()) {
            tmpA = tmp * ((iMinimum / tmp));
            tmpB = tmp * ((iMaximum / tmp));
        } else {
            tmpA = iMinimum;
            tmpB = iMaximum;
It should say now:
            tmpA = tmp * (int) ((iMinimum / tmp));
            tmpB = tmp * (int) ((iMaximum / tmp));
        } else {
            tmpA = iMinimum;
            tmpB = iMaximum;
WST
Post by WST » Wed May 28, 2014 11:37 pm
Thanks, that fixed the issue for us.
