Back Wall LoadImage
sol
Back Wall LoadImage
Post by sol » Thu Oct 02, 2014 10:55 am
Good Morning
TeeChart Build 3.2014.0519
IDE Eclipse
Language Android
OS. Windows 7 32 bit
Problem is Loading a png image to back wall so appears between left axis and bottom axis,
but the same image is appearing over left axis see attached file.
// Code
private void drawGraph(){
		//Draw TeeChart
		int nTests = m_arrayTestData.size();
	    // chart.setAutoRepaint(false); //optional, disable repaints whilst setting up chart variables
	    	//...call here to any Chart setup routines
	       // Clear previous graph from chart.
	     chart.removeAllSeries();
	      Color clrPanel = new Color(context.getResources().getColor(R.color.Black));
	      Color clrBlack = new Color(context.getResources().getColor(R.color.Black));
	      chart.getPanel().setColor(clrPanel);
	      //Set legend background black with white text.
	      chart.getLegend().getBrush().setColor(clrPanel);
	      Color clrWhite = new Color(context.getResources().getColor(R.color.White));
	      chart.getLegend().getFont().setColor(clrWhite);
	      chart.getLegend().getFont().setSize(18);
	      chart.getLegend().setVisible(false);
		    // Load Graph background with Health Regions Chart.
		     // Load image of Health Regions for background of chart.
	 		    Bitmap bitmapLogo = BitmapFactory.decodeResource(activity.getResources(),
	 		      		R.drawable.health_regions_chart);
	 		  String strFilename = null;
	 		  try {
	             if(bitmapLogo!=null)
	                 //save image to Pictures for Chart to read.
	            	 strFilename = saveImage(bitmapLogo,"Health_Regions.png");
	             } catch (IOException e) {
	             // TODO Auto-generated catch block
	             e.printStackTrace();
		  /*   Fills whole of graph area to the very edge.
		    if(strFilename != null)
		      chart.getPanel().getBrush().loadImage(strFilename);
	 		 // Fill between Axises Background.
			      chart.getWalls().getBack().getBrush().loadImage(strFilename);
	 	  // Set Back wall
	 	  chart.getPanel().getGradient().setVisible(false);
	 	  chart.getWalls().getBack().getGradient().setVisible(false);
	 	chart.getWalls().getBack().setVisible(true);
	 	//   chart.getWalls().getBack().setColor(Color.RED);
	     chart.getWalls().getLeft().setVisible(false);
	     chart.getWalls().getRight().setVisible(false);
	     chart.getWalls().getBottom().setVisible(false);
	       /** X-Y */
	       chart.getAxes().getBottom().setIncrement( 1 );
           // Plot
           try { // X point Y point L
  			    plot = new Points(chart.getChart().chart);
  		} catch (IllegalArgumentException e1) {
  			e1.printStackTrace();
 		   plot.setColor(Color.YELLOW);
 		   plot.getLinePen().width = 50;
	     // Load chart with data.
	   //  int i=0;
	   //  for(i=0;i<nTests;i++)
	   //     plot.add( m_arrayTestData.get(i), m_arrayTestData_TestDate.get(i),aDataColor  );
	     plot.add(impedance,phase);
	     //Box above bars set background to black
	     // and have white text.
	     plot.getMarks().getFont().setColor(clrWhite);  // Text color.
	     plot.getMarks().getFont().setSize(18);         // Text size Number above bar.
	     plot.getMarks().getFont().setBold(true);
	     // No Tick under value above bar.
	     plot.getMarks().setArrowLength(0); // Places on bar top.
	     plot.getMarks().getBrush().setColor(clrWhite); // Box color.
	     // set marks to data value instead of cylinder number?
	     plot.getMarks().setStyle(MarksStyle.VALUE);
	     String strTitle = appState.getStateFullName();
	     strTitle += "         ";  // Gap between statements.
	     strTitle += context.getResources().getString(R.string.ProgressFatper);
	     // Display number of tests on title.
	     String str;
	     if(m_arrayTestData.size() > 1)
	         str = String.format("%s %d",
	        		 context.getResources().getString(R.string.Tests),m_arrayTestData.size(),locale);
	    			 context.getResources().getString(R.string.Test),m_arrayTestData.size(),locale);
	     strTitle += str;
	     //The background is white.
	     // So configure text to be black.
	      chart.getAxes().getLeft().getLabels().getFont().setColor(clrWhite);
	     // Y Axis
	     chart.getAxes().getLeft().getAxisPen().setColor(clrWhite);
	     chart.getAxes().getLeft().getLabels().getFont().setSize(18);
	     // Y Axis Title.
	     str = context.getResources().getString(R.string.BioMarker);
	     chart.getAxes().getLeft().getTitle().setText(str);
	     chart.getAxes().getLeft().getTitle().getFont().setColor(clrWhite);//
	     chart.getAxes().getLeft().getTitle().getFont().setSize(18);
	     // Set Y Axis plot range manually.
	     chart.getAxes().getLeft().setAutomatic(false);
	     // Adult Males
	     if(appState.getStateIntGender() == BioScanConstants.MALE){
	         chart.getAxes().getLeft().setMaximum(12f);
	         chart.getAxes().getLeft().setMinimum(2f);
	     else{
	    	 // Adult Females and Children
	    	 chart.getAxes().getLeft().setMaximum(11f);
	         chart.getAxes().getLeft().setMinimum(1f);
	     // X -Axis
	     chart.getAxes().getBottom().setAutomatic(false);
	     // Adult Males
	        chart.getAxes().getBottom().setMaximum(750f);
	        chart.getAxes().getBottom().setMinimum(200f);
	     else{  // Adult Females and Children
	    	    chart.getAxes().getBottom().setMaximum(850f);
		        chart.getAxes().getBottom().setMinimum(300f);
	     chart.getAxes().getBottom().getAxisPen().setColor(clrWhite);
	     chart.getAxes().getBottom().getLabels().getFont().setColor(clrWhite);
	     chart.getAxes().getBottom().getLabels().getFont().setSize(18);
	     chart.getAxes().getBottom().getLabels().getFont().setBold(true);
	     str = context.getResources().getString(R.string.Impedance);
	     chart.getAxes().getBottom().getTitle().setText(str);
	     chart.getAxes().getBottom().getTitle().getFont().setSize(18);
	     chart.getAxes().getBottom().getTitle().getFont().setColor(clrWhite);
	     // Graph Title
	     // No Title
	     // chart.getHeader().getFont().setSize(24);
	     strTitle = "";
	     chart.getHeader().setText(strTitle);
	     // chart.getHeader().getFont().setColor(clrWhite);
	     // left axis grid
	     chart.getAxes().getLeft().getGrid().setColor(clrBlack);
	     // bottom axis grid
	     chart.getAxes().getBottom().getGrid().setColor(clrBlack);
	     // similar function for getTop() and getRight() grids.
	     // Removes outer rectangle round whole of graph
	  //   chart.getPanel().setBevelOuter(BevelStyle.NONE);
	   // Diagnoised
	       String msg;
	       String strFullname = appState.getStateFullName();
    	   int n = m_arrayTestData.size();
    	   msg = String.format("%s %s %d %s %d",
    			   "Drawn Graph",strFullname,n,dataName,dataItem);
    	   DisplayToast(msg);
	     // Save bar chart to Bitmap file.
	     chart.doInvalidate();
	     Image image = chart.getExport().getImage().image(400, 200);
	     // Save to  Android memory folder
	     // data/data/(app id)in.wptrafficanalyzer.viewpagerdemo/files
	     try {
	    	  	FileOutputStream out = activity.openFileOutput("targetFat.png", Context.MODE_PRIVATE);
	    	  	image.save(out);
	    	  	out.flush();
	    	  	out.close();
	    } catch (Exception e) {
	  }// End of drawGraph
Back Wall load Image.png (159.62 KiB) Viewed 78612 times
Re: Back Wall LoadImage
Post by Yeray » Thu Oct 02, 2014 1:37 pm
I'm afraid there are some functions and resources I don't have here so we can't run this here.
Could you please arrange a simple but self-containing example we can run as-is to reproduce the problem here?
http://www.sscce.org/
sol
Post by sol » Fri Oct 03, 2014 1:54 pm
To Yeray
Thank-you for the quick response.
Please find attached zip file containing three files
MainActivity.java self containing example
healthregionschart.png background image used to go over chart
and the manifest because need to set Write internal storage and write external storage permissions.
The example shows image between axis as required.
But there is a second reduced image overlapping the y-Axis.
selfcontainingExample.zip
(28.17 KiB) Downloaded 3575 times
Post by Yeray » Fri Oct 03, 2014 3:50 pm
Simplifying your testing app, this still reproduces the problem:
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        createChart();
        testLoadImage();
	private TChart tChart1;
	private void createChart() {
		LinearLayout layout = (LinearLayout) findViewById(R.id.chart_layout1);
		tChart1 = new TChart(this);
		layout.addView(tChart1);
	private void testLoadImage() {
				getApplicationContext().getResources(),
		tChart1.getWalls().getBack().getBrush().setImage(new Image(bitmapLogo));
I've added this to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=943
sol
Post by sol » Mon Oct 06, 2014 11:36 am
Yeray,
When can I expect this bug to be fixed as required by our Android program?
Solomon
Post by Yeray » Tue Oct 07, 2014 1:20 pm
Hi Solomon,
sol wrote:When can I expect this bug to be fixed as required by our Android program?
I've just applied a fix for this in our internal sources and I've closed the ticket, so the next maintenance release will include the fix.
sol
Post by sol » Wed Oct 08, 2014 11:57 am
To Yeray,
Excellent news that you have fixed the problem.
Could you please explain how to download the Maintenance Release. (Android Mobile)
Post by Yeray » Wed Oct 08, 2014 12:08 pm
sol wrote:Could you please explain how to download the Maintenance Release. (Android Mobile)
The maintenance releases are announced in the news feed, this forum, Twitter and Facebook.
I'm afraid I can't tell you when the next one (including this fix) will be published.
When it will be published and announced, the download will be available in the client area, as usual.
