Showing gaps in Fastline series…
I have one problem and one question:
At first the question: The snap function snaps to the nearest data point of a Fastline data series. Unfortunately, it marks NULL points too.
Is it possible to change this behaviour, so that only visible points will be snapped?
My problem is the line drawing between several points including a gap:
I'm using Fastline series to show bigger data series (1-3 Mio data points), but the problem appears with 10 data points too.
The chart performance of the function setDrawAllPoints(false) works for me.
But I realized several situations, where the line drawing between two points is not what I'm expecting:
Example:
A Fastline data series with a time axis contains 5 Points: 500, 2000, NULL (I want a gap), 0,1, ...
I expect a line from 500 to 2000, a gap and the next line from 0 to 1. The one picture shows the right drawing.
But from time to time, the diagram with the same data looks like the other one picture - the gap is missing and there's a "wrong" drawing from 2000 down to 0. The only change is a wider or smaller time-line on the x axis or a bigger or smaller window - but there's no clear relation: One time, it is right, the next time it is wrong.
I changed the data series to Line and the problem disappeared. Unfortunately, Line is not able to show 1-3 mio. data points.
Is there a solution?
Best regards
Konrad
Example:
Best regards
Konrad
- Wrong drawing
- Wrong drawing.jpg (74.42 KiB) Viewed 111624 times
- Right Drawing
- Right drawing.jpg (70.97 KiB) Viewed 111626 times
Re: Showing gaps in Fastline series…
http://bugs.teechart.net/show_bug.cgi?id=1999
I'm trying to reproduce the problem about the null points that are sometimes being drawn using the example below, but it seems to work as expected for me here:
We'd need to reproduce the problem consistently in order to fix it.
I'm afraid the NearestPoint tool doesn't seem to check the null points. I've added it to the public tracker and already fixed it for the next maintenance release.Konrad wrote:At first the question: The snap function snaps to the nearest data point of a Fastline data series. Unfortunately, it marks NULL points too.
FastLine fast1 = new FastLine(tChart1.getChart());
for (int i = 0; i < 2000; i++) {
if (i == 1000)
fast1.addNullXY(i, 200);
fast1.add(i, 100);
fast1.setTreatNulls(TreatNullsStyle.DONOTPAINT);
fast1.setDrawAllPoints(false);
tChart1.getAxes().getBottom().setMinMax(0, 2000);
tChart1.getAxes().getLeft().setMinMax(0, 300);
thank you for your help!
At what time, the maintenance update will be available?
I added a little neatbeans project which will show the behaviour. You just have to add the TeeChart.Swing.jar to the project to run it.
Please start the program and press the "load" button.
Start it a second time and change the window size (make it a little bit bigger) befor pressing the "load" button.
It's the same data series, but the drawing will be different.
Best regards, Konrad
- Demo.zip
- (18.38 KiB) Downloaded 5314 times
I could reproduce that problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=2003
Note I've already fixed it.
I can't find a current license for your account. I could send you the current sources if you have a non-expired license. Otherwise, I'm afraid you'll have to wait for the next maintenance release.Konrad wrote:At what time, the maintenance update will be available?
I have an older license from 2009. If both problems are fixed, I would buy a newer license or an upgrade incl. the support package.
What's the best way, to get a Version including the fixes? They are actually not included in the latest version I can buy / download?
Best regards,
Konrad
Best regards,
Konrad
the problem is solved, when i use fastline series without setting setDrawAllPoints(false) and setDrawAllPointsStyle(DrawAllPointsStyle.MinMax).
But if I do so, because of the big amount of data I wish to display, the bug appears again.
It was my fault, that it was not enabled in the demo application - sorry.
Could you please take another look to this Problem?
Thank you in advance!
Best regards
Konrad
Best regards
Konrad
I could reproduce it so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=2008
could you tell me please, at what time this bug will be fixed?
Would it be fixed earlier, if I buy a new license with priority support?
Best regards
Konrad
Best regards
Konrad
Hi Konrad,
We are taking a look at the issue to see if we can find a fix.
I'm afraid we can't say when the tickets will be closed. See the Bug Fixing Policy.Konrad wrote:could you tell me please, at what time this bug will be fixed?
No, the Pro Support subscription gives you the advantages described in the Support Options page.Konrad wrote:Would it be fixed earlier, if I buy a new license with priority support?
thank you very much for your Support - that would be very kind of you!
I hope there is an easy and quick solution.
Best regards
Konrad
Best regards
Konrad
Hello Konrad,
I'll send you a FastLine.java test version so you can check if it works fine.
