Array Index Out of Bounds Exception
Turc
Post by Turc » Thu May 16, 2013 2:18 pm
I have a real time chart. I plot about 3 points per second. I plot points in the range of 0-300, about 3200 points at most.
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: 3552
at com.steema.teechart.styles.FastLine.calcPosition(FastLine.java:245)
at com.steema.teechart.styles.FastLine.drawValue(FastLine.java:297)
at com.steema.teechart.styles.FastLine.draw(FastLine.java:273)
at com.steema.teechart.styles.Series.drawSeries(Series.java:2274)
at com.steema.teechart.Chart.internalDraw(Chart.java:756)
at com.steema.teechart.Chart.paint(Chart.java:2031)
at com.steema.teechart.TChart.paintComponent(TChart.java:616)
at javax.swing.JComponent.paint(JComponent.java:1037)
at javax.swing.JComponent._paintImmediately(JComponent.java:5106)
at javax.swing.JComponent.paintImmediately(JComponent.java:4890)
at javax.swing.RepaintManager$3.run(RepaintManager.java:814)
at javax.swing.RepaintManager$3.run(RepaintManager.java:802)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:802)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:745)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:725)
at javax.swing.RepaintManager.access$1000(RepaintManager.java:46)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1684)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:708)
at java.awt.EventQueue.access$400(EventQueue.java:82)
at java.awt.EventQueue$2.run(EventQueue.java:669)
at java.awt.EventQueue$2.run(EventQueue.java:667)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:678)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Re: Array Index Out of Bounds Exception
Post by Yeray » Thu May 16, 2013 4:15 pm
Can you please arrange a simple example project we can run as-is to reproduce the problem here?
