ChartMouseListener events error using ZoomStyle.INCHART
Novus
Post by Novus » Wed Aug 20, 2014 1:56 pm
After starting to use the ZoomStyle.INCHART_MULTI im my charts, the ChartMouseListener events stopped working, how can I reuse the backgroundClicked(ChartMouseEvent arg0)) event with this style of zoom?
chart.getZoom().setZoomStyle(ZoomStyle.INCHART_MULTI);
chart1.addChartMouseListener(new ChartMouseListener() {
			@Override
			public void titleClicked(ChartMouseEvent arg0) {
				// TODO Auto-generated method stub
			@Override
			public void legendClicked(ChartMouseEvent arg0) {
			@Override
			public void backgroundClicked(ChartMouseEvent arg0) {
                               This event is no longer triggered with this zoom Style
			@Override
			public void axesClicked(ChartMouseEvent arg0) {
Re: ChartMouseListener events error using ZoomStyle.INCHART
Post by Yeray » Thu Aug 21, 2014 11:11 am
Hello Novus,
I could reproduce the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=894
Post by Yeray » Thu Aug 21, 2014 11:13 am
Hi again,
I've already found a fix for it so the next maintenance release will include it.
I see you own the TeeChart sources so here it is the fix:
At TChart.java, at the beginning of the onTouch method you'll see this:
	public boolean onTouch(View v, MotionEvent event) {
		switch (event.getAction()) {
		case MotionEvent.ACTION_DOWN: {
			if (chart.getZoom().getZoomStyle() != ZoomStyle.INCHART_MULTI)
			  triggerEvent(event, FrameworkMouseEvent.MOUSE_PRESSED);
Just remove the if condition to have this:
Novus
Post by Novus » Thu Aug 21, 2014 5:41 pm
thanks, I'll try to modify the source code here.
