DragPoint Events in Java
swappyk
Post by swappyk » Fri Sep 02, 2016 1:27 pm
I am implementing a Dragpoint event for my chart in Java, and now I want to capture the values after the drag point event is done and save them to DB. I see the legend is being updated with the values but I am not able to capture the values. Can you suggest a way to capture the data after the Drag is complete
Re: DragPoint Events in Java
Post by Yeray » Mon Sep 05, 2016 9:34 am
You can use events as in the following SWT example:
    static int draggingIndex = -1;
    static Series draggingSeries = null;
    static Point mousePos = null;
	private static void dragTest() {
		tChart1.getHeader().setVisible(false);
        //tChart1.getLegend().setVisible(false);
        tChart1.getZoom().setActive(false);
        Points points1 = new Points(tChart1.getChart());
        points1.fillSampleValues(10);
        DragPoint dragPoints1 = new DragPoint(tChart1.getChart());
        tChart1.addMouseMoveListener(new MouseMoveListener() {
			@Override
			public void mouseMove(MouseEvent arg0) {
				mousePos = new Point(arg0.x, arg0.y);
        dragPoints1.addDragListener(new DragListener() {
			@Override
			public void dragMoving(ChangeEvent e) {
				if (draggingSeries == null) {
					draggingIndex = ((DragPoint)e.getSource()).getDragPoint();
					for (int t = 0; t < tChart1.getSeriesCount(); t++) {
						Series s = tChart1.getSeries(t);
						if (s.getActive()) {
							int clickedIndex = s.clicked(mousePos);
							if ((draggingIndex != -1) && (clickedIndex != -1) && (clickedIndex == draggingIndex)) {
								draggingSeries = s;
								break;
			@Override
			public void dragFinished(ChangeEvent e) {
				if ((draggingSeries != null) && (draggingIndex != -1)) {
					System.out.println(draggingSeries.getYValues().getValue(draggingIndex));
				draggingIndex = -1;
swappyk
Post by swappyk » Wed Sep 07, 2016 1:43 pm
Can we do the same using Swing components. My project is a swing project?
Post by Yeray » Thu Sep 08, 2016 9:48 am
It's quite similar in Swing. I've improved the code a bit:
          tChart1.addMouseListener(new MouseAdapter() {
			@Override
			public void mousePressed(MouseEvent e) {
				if (dragPoints1.getSeries() == null) {
	                        draggingIndex = s.clicked(e.getX(), e.getY());
	                        if (draggingIndex != -1) {
	                            draggingSeries = s;
	                            break;
	            } else {
	                draggingIndex = dragPoints1.getSeries().clicked(e.getX(), e.getY());
	                    draggingSeries = dragPoints1.getSeries();
          dragPoints1.addDragListener(new DragAdapter() {
           @Override
              draggingIndex = -1;
swappyk
Post by swappyk » Wed Oct 05, 2016 10:52 am
I have a chart with multiple Lines, Yet I want to enable just one of the lines as draggable. The other lines have to remain static.
Post by Yeray » Thu Oct 06, 2016 7:47 am
Have you tried to do it with the code I posted here?
http://www.teechart.net/support/viewtop ... 396#p72396
swappyk
Post by swappyk » Mon Oct 10, 2016 3:10 pm
Yes,
In that code I am able to move all the lines, here is what i am talking about.
I have a TChart with 4 lines, however I want to able to move only one of the lines using DragPoint Tool. The other 3 lines should not be moved. I tried to add series to DragPoint class constructor, but I am not able to get the chart to work how i want it to work.
Post by Yeray » Tue Oct 11, 2016 8:51 am
Knowing the index of the series you want the dragging to be allowed (ie draggableSeriesIndex), you can change the mousePressed event to fit your needs. Ie:
         @Override
             Series s = tChart1.getSeries(draggableSeriesIndex);
                   draggingSeries = s;
                   OldXPos = e.getX();
                   OldYPos = e.getY();
                   break;
