Font for chart text (chart title, axis title, axis labels ..
Chen
Post by Chen » Thu Jun 26, 2008 4:44 pm
I am not able to apply different types of fonts to text available in the chart.
Eg: I am using FontDialog from SWT, If I select a font from the list of available fonts for the platform and apply it to the chart title, then it seems that TeeChart is ignoring most of the fonts. I ran your demo application and used chart editor to perform the same operations. But got the same result. It would be great if I can get a clarification from your side.
Varun
Post by Narcís » Fri Jun 27, 2008 8:55 am
Hi Varun,
Which exact TeeChart version are you using? There was an issue with fonts that was fixed in build 1.0.1.840 from 19th May 2008 as you can see in the release notes.
Chen
Post by Chen » Fri Jun 27, 2008 11:23 pm
I was using November 2007 build. I downloaded new version and it is working fine now.
Varun
