Supprt for Servlet or JSP? SWT is not working.
SDG
Post by SDG » Mon May 11, 2009 9:14 am
Does teechart has components for Servlet or JSP? When I am calling TeeChartSWT.java from webserver, I get following error.
Client:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Wrapper cannot find servlet class TeeChart.TeeChartSWT or a class it depends on
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
java.lang.Thread.run(Unknown Source)
root cause
java.lang.ClassNotFoundException: TeeChart.TeeChartSWT
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1359)
org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1205)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.23 logs.
Tomcat Server:
SEVERE: Error loading WebappClassLoader
delegate: false
repositories:
/WEB-INF/classes/
----------> Parent Classloader:
org.apache.catalina.loader.StandardClassLoader@64f6cd
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1359)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1205)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1068)
at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:791)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:127)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
at java.lang.Thread.run(Unknown Source)
May 11, 2009 2:41:25 PM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Allocate exception for servlet TeeChartSWT
Kindly advise me on running SWT examples on WebServer.
Also I would like to know the difference between SWT and Swing and AWT.
Post by Marc » Tue May 12, 2009 9:04 am
Re.
The error message suggests that project references to TeeChart may be incorrect, that it can't find the location of TeeChart. Please check that TeeChart is correctly referenced in the project.
We don't have a servlet example prepared at this moment but we'll look to preparing one for reference purposes.
Re.
AWT functionality is common to both the Swing and SWT versions of TeeChart. TeeChart's Swing implementation includes Editor dialogues whereas the SWT doesn't, except for Print Preview. That is the key functionality difference between the two versions.
