Is it possible to center the marks on a Bar and a HorizBar?
And if it is possible how do I do it?
I am using the TeeChartPHP2012.10.08.001_with_Sources version
Center mark in Bar and HorizBar
Re: Center mark in Bar and HorizBar
Hi Martin,
MarksOnBar is a feature added in TeeChart VCL quite recently. I've added to the with list the possibility to port it to the PHP version (TF90016436).
So it's not possible right know to center a mark?
How about the Gantt() ? The mark is centered there.
Or does that work different?
In the meanwhile you could calculate and set the marks positions manually. Here you have an example:
$chart = new TChart(700,500);
$chart->getAspect()->setView3D(false);
$bar = new Bar($chart->getChart());
$bar->fillSampleValues();
$bar->getMarks()->getArrow()->setVisible(false);
$chart->doInvalidate();
for($i=0;$i<sizeof($bar->getMarks()->getPositions());$i++) {
$p = $bar->getMarks()->getPositions()->getPosition($i);
if ($p!=null) {
$p->custom = true;
$p->leftTop->y = ($chart->getAxes()->getBottom()->getPosAxis() + $bar->calcYPos($i)) / 2;
$chart->render();
They have indeed a custom position.
But not the position I want.
I have the bars 'stacked'.
Does that influence the behavior of the marks?
- custom_mark_pos.JPG (35.64 KiB) Viewed 73201 times
Hi Martin,
The different possibilities like Bar/HorizBar series, or the MultiBar style (Stacked,...) should be handled manually while the MarksOnBar feature isn't implemented.
Here you can find an example in VCL where the same was discussed.
http://www.teechart.net/support/viewtop ... bar#p59305
