Looking for example to send graph direct to browser
The demos show a .png file being created. How do avoid that and send the graph to the browser without creating a .png file?
Re: Looking for example to send graph direct to browser
The charts in TeeChart PHP must be created at server-side but instead of creating a png as follows:
You can directly send the stream calling the same function without parameters:
$chart->render("chart1.png");
$chart->render();
Thanks for the reply. If I try that I get the following error message.
Fatal error: Call to undefined function imageftbbox() in /usr/local/uptime/GUI/teeChart/sources/GraphicsGD.php on line 2504
I need to have teeChart in a slightly unusual location... Do I have to do something special for that?
-Randy
-Randy
Hello Randy,
Many apologies for the delayed reply.
Find attached an example calling render() without parameters and sending the chart to the browser as a stream. Hope this solves the problem at your end.
- demo_php_render_stream.zip
- (946 Bytes) Downloaded 1916 times
