Cannot run TeeChart.Installer.jar in Window XP Pro
TeeChart for PHP
ahartnoll
Post by ahartnoll » Wed May 13, 2009 6:01 pm
When trying to run the .jar file, I get the following error:
"Could not find the main class. The program will exit"
I am running Java jre1.5.0_17
Post by Pep » Mon May 18, 2009 4:00 pm
it's strange, I've test it here and worked fine. Could you please try to download the zip from our web site again ?
Could you please also check if this happens with another machine ?
I'f you still having problem let us know so we can send the files to you to be able to use them in meantime.
