IOS fail to compile
jls
IOS fail to compile
Post by jls » Tue May 29, 2012 9:25 am
The compile on the MAC fails
I use the latest version (update 4 with hotfix)
also copied files to
/Developer/Embarcadero/fmi
The project is your demo program.
Any idea whats wrong?
Jørgen
Screen Shot 2012-05-29 at 11.08.36 AM.jpg (459.56 KiB) Viewed 14119 times
Re: IOS fail to compile
Post by Yeray » Thu May 31, 2012 2:16 pm
Hi Jørgen,
It seems the compiler doesn't find an "info.plist" file, right? I'm afraid this isn't a TeeChart file. It's a file xcode should create automatically when the application is created. I think it should be in your application folder. Can you find it manually?
jls
Post by jls » Tue Jun 12, 2012 10:23 am
now it works
Post by Yeray » Tue Jun 12, 2012 10:43 am
Hi Jørgen,
Please, don't hesitate to share the solution if you feel it could help others with a similar problem.
jls
Post by jls » Wed Jun 13, 2012 10:12 am
Probably something with my search path or uses clause
It just started to work. :D
Jørgen
