Custom Axes issue
Custom Axes issue
Postby Peter Carr » Sun Jul 16, 2017 5:35 pm
To reproduce the issue, add a TChart to a FMX Multi-Device Application and insert the code below into the implementation section.
The code below adds two custom tick marks and labels to the TChart bottom axis and sets the axis labels to be large and red. It works fine in Delphi 10.1 Berlin with Teechart Pro v2017.21.170329 32 bit FMX. It does not work in Delphi 10.2 Tokyo with Teechart Pro v2017.22.170619 32 bit FMX, where the custom labels appear at default size and in black.
Is this a bug or am I doing something wrong. If a bug, is there a workaround until you fix it?
uses
  FMXTee.Series, System.UIConsts;
procedure TForm3.FormCreate(Sender: TObject);
  Chart1.View3D := False;
  Chart1.Axes.Bottom.SetMinMax(1, 10);
  Chart1.Axes.Bottom.Items.Add(2, '2');
  Chart1.BottomAxis.Items.Add(5, '5');
  // Make bottom axis tick labels big and red
  Chart1.BottomAxis.LabelsFont.Size := 30;
  Chart1.BottomAxis.LabelsFont.Color := claRed;
Peter Carr
Re: Custom Axes issue
Postby Christopher » Mon Jul 17, 2017 1:28 pm
Many thanks for reporting this issue to us - it is a defect which I have added to our issue-tracking database with id=1894. At the moment I cannot suggest a workaround for you, but if I discover one in the near future I will certainly pass it on to you.
Postby Peter Carr » Wed Aug 09, 2017 6:58 am
As a workaround, I have reverted to using the v2017.21 Teechart in Delphi 10.2 Tokyo. In other words, I am skipping v2017.22 due to this bug.
Peter Carr
Postby Sandra » Wed Aug 09, 2017 9:51 am
Hello Peter,
Many thanks for the information. I have added the information to the bug id=1894.
Thanks in advance
Return to FMX
Who is online
Users browsing this forum: No registered users and 2 guests
