The compile on the MAC fails
I use the latest version (update 4 with hotfix)
also copied files to
/Developer/Embarcadero/fmi
The project is your demo program.
Any idea whats wrong?
Jørgen
IOS fail to compile
IOS fail to compile
- Screen Shot 2012-05-29 at 11.08.36 AM.jpg (459.56 KiB) Viewed 11646 times
Re: IOS fail to compile
Hi Jørgen,
It seems the compiler doesn't find an "info.plist" file, right? I'm afraid this isn't a TeeChart file. It's a file xcode should create automatically when the application is created. I think it should be in your application folder. Can you find it manually?
now it works
Hi Jørgen,
Please, don't hesitate to share the solution if you feel it could help others with a similar problem.
Probably something with my search path or uses clause
It just started to work.
Jørgen
Jørgen
