How to method not drawing outside in graph axis
lindev
Post by lindev » Fri Nov 30, 2012 2:26 am
I want to know method for not drawing outside in graph axis on graph drawing.
First, I tried to use ClipPoints property.
code is following.
chart = GetChartName(0, chartindex, all);
chart->ClipPoints = true;
But it code is not effectively.
How to solve this problem?
Re: How to method not drawing outside in graph axis
Post by Yeray » Fri Nov 30, 2012 11:06 am
You are right, I'm afraid the clipping doesn't work well in FMX (TV52015963).
lindev
Post by lindev » Fri Nov 30, 2012 1:16 pm
Oh...
Is It bug on TeeChart ?
Post by Yeray » Fri Nov 30, 2012 3:18 pm
It's something we expect to be able to achieve, bug or feature request.
lindev
Post by lindev » Tue Dec 04, 2012 1:42 am
Thank you for the information.
I hope that have the similar clipping effect as VCL.
Do you know how to solve in a different way?
Post by Yeray » Tue Dec 04, 2012 8:41 am
The only way I can think to work around this is to manually check, at OnScroll and OnZoom events, if all the points are in the ChartRect, and set as null those that aren't.
lindev
Post by lindev » Wed Dec 12, 2012 8:52 am
I solved that I implement the your idea.
