XE5 TeeRecompile.exe problem
makoto
Post by makoto » Mon Dec 16, 2013 5:47 am
couldn't recompile by TeeRecompile.exe.
file not exist FMXTee.Editor.TextShape.pas.
before
after
Re: XE5 TeeRecompile.exe problem
Post by Yeray » Tue Dec 17, 2013 1:03 pm
I could reproduce the problem and we are working on a solution. We'll be back to you here asap.
Post by Yeray » Wed Dec 18, 2013 2:30 pm
We've just uploaded a new Beta installer for the Standard with Sources and Pro with Sources versions correcting the problem.
http://www.steema.com/clientaccess
makoto
Post by makoto » Thu Dec 19, 2013 1:11 am
Thank you.
Please tell me the recommended setting of Recompile.
TeeChart Source Code folder:
C:\Program Files (x86)\Steema Software\TeeChart Standard 2013 Source Code\Sources
Relative destination:
Compiled ??
Copy binary files to:
And Please tell me delphi settings to run in iOS Device.
my environment is
windows7 enterprise 64bit.
Delphi XE5 Update2
makoto
Post by makoto » Fri Dec 20, 2013 1:36 am
I was Recompile.
TeeChart Standard
Compilation started: 2013/12/20 10:27:49
Win32 v19 (Delphi XE5 and C++Builder XE5 Update 2)
Tee919
Embarcadero Delphi for Win32 compiler version 26.0
Copyright (c) 1983,2013 Embarcadero Technologies, Inc.
85631 ・s, 0.66 ・b, ・R・[・h 940872 ・o・C・g, ・f・[・^ 4516 ・o・C・g
TeeUI919
78581 ・s, 0.53 ・b, ・R・[・h 609472 ・o・C・g, ・f・[・^ 1364 ・o・C・g
TeeDB919
8408 ・s, 0.23 ・b, ・R・[・h 87412 ・o・C・g, ・f・[・^ 288 ・o・C・g
DclTee919
9150 ・s, 0.50 ・b, ・R・[・h 157988 ・o・C・g, ・f・[・^ 360 ・o・C・g
DclTeeStd919
10156 ・s, 0.38 ・b, ・R・[・h 170152 ・o・C・g, ・f・[・^ 348 ・o・C・g
FMXTee919
79712 ・s, 1.29 ・b, ・R・[・h 883572 ・o・C・g, ・f・[・^ 4144 ・o・C・g
FMXTeeUI919
63912 ・s, 0.55 ・b, ・R・[・h 539068 ・o・C・g, ・f・[・^ 1076 ・o・C・g
FMXTeeDB919
8307 ・s, 0.37 ・b, ・R・[・h 90576 ・o・C・g, ・f・[・^ 288 ・o・C・g
DclFMXTee919
4363 ・s, 0.48 ・b, ・R・[・h 118072 ・o・C・g, ・f・[・^ 268 ・o・C・g
DclFMXTeeStd919
4363 ・s, 0.47 ・b, ・R・[・h 118072 ・o・C・g, ・f・[・^ 268 ・o・C・g
EXCEPTION:
Cannot copy file: D:\TeeChartStandard2013Standard\Delphi19.win32\System\Tee919.bpl to D:\TeeChartStandard2013\Tee919.bpl
Error Code: 3 Description: 指定されたパスが見つかりません。
D:\TeeChartStandard2013Standard\Delphi19.win32\System\Tee919.bpl is Exists.
D:\TeeChartStandard2013Standard\Delphi19.win32\System>dir
ドライブ D のボリューム ラベルは ボリューム です
ボリューム シリアル番号は 0409-A8DA です
D:\TeeChartStandard2013Standard\Delphi19.win32\System のディレクトリ
2013/12/20 10:27 <DIR> .
2013/12/20 10:27 <DIR> ..
2013/12/20 10:27 1,465,344 FMXTee919.bpl
2013/12/20 10:27 217,088 FMXTeeDB919.bpl
2013/12/20 10:27 1,341,952 FMXTeeUI919.bpl
2013/12/20 10:27 1,884,160 Tee919.bpl
2013/12/20 10:27 201,728 TeeDB919.bpl
2013/12/20 10:27 1,397,760 TeeUI919.bpl
6 個のファイル 6,508,032 バイト
2 個のディレクトリ 82,885,021,696 バイトの空き領域
Post by Yeray » Fri Dec 20, 2013 9:52 am
Here it is a snapshot:
makoto wrote:Please tell me the recommended setting of Recompile.
I installed the sources to a slightly modified path because I have many TeeChart installations I want to keep:
C:\Program Files (x86)\Steema Software\TeeChartVCL\TeeChart Standard 2013.09.131217 Source Code (Beta)
You can see the rest of the settings in the snapshot, I just use the default settings TeeRecompile suggests.
makoto wrote:And Please tell me delphi settings to run in iOS Device.
Nothing special for TeeChart. Just the same requirements and procedure than with any other iOS application in XE5.
http://docwiki.embarcadero.com/RADStudi ... evelopment
http://docwiki.embarcadero.com/RADStudi ... iOS_Device
makoto wrote:EXCEPTION:
Maybe it's the D:\TeeChartStandard2013 path, the destination path, the one that doesn't exist.
If you still find any problem with it, please don't hesitate to let us know.
makoto
Post by makoto » Mon Dec 23, 2013 5:49 am
Thanks!
TeeRecompile was completed.
but couldn't build my project for iOS Device.
[DCC 致命的エラー] FmPlanLoanGraph1.pas(8): F1026 ファイル 'D:\Project\FPL\FpCalcTest\FpCalcSFC4Delphi\FMXTee.Engine.dcu' が見つかりません
iOS Simulator was able to build.
TeeRecompile log are
iOS Device v19 (Delphi XE5 and C++Builder XE5 Update 2)
Compiling... unit
Embarcadero Delphi Next Generation for iPhone compiler version 26.0
Copyright (c) 1983.2013 Embarcadero Technologies, Inc.
FMXTee.Editor.DBChart.pas(200) ・q・・・g: H2443 ・C・・・・・C・・・ヨ・・ 'TControl.GetCanvas' ・ヘ・・・j・b・g 'FMX.Graphics' ・ェ USES ・・・X・g・ナ・w・・・ウ・・・ト・「・ネ・「・ス・゚・W・J・ウ・・・ワ・ケ・・
153128 ・s・A90.43 ・b・B
Binding Units
73859 ・s・A18.13 ・b・B
TeeChart Installation
VERSION: 2013
Installing...
iOS Device v19 (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 1m 51s
and "C:\Program Files (x86)\Steema Software\TeeChart Standard 2013 Source Code\Sources\compiledStandard\Delphi19.iOSDevice\Lib" was
s\compiledStandard\Delphi19.iOSDevice\Lib>dir /b
FMXTee.About.o
FMXTee.Animate.o
FMXTee.Animations.Gallery.o
FMXTee.Animations.o
FMXTee.Animations.Tools.o
FMXTee.Bind.Chart.dcu
FMXTee.Bind.Chart.o
FMXTee.Bind.DBLinks.dcu
FMXTee.Bind.DBLinks.o
FMXTee.Bind.Editors.dcu
FMXTee.Bind.Editors.o
FMXTee.Canvas.o
FMXTee.Chart.Crosstab.o
FMXTee.Chart.Functions.o
FMXTee.Chart.GalleryPanel.o
FMXTee.Chart.Grid.o
FMXTee.Chart.ListBox.o
FMXTee.Chart.ListBox.Style.res
FMXTee.Chart.o
FMXTee.Chart3D.o
FMXTee.Constants.o
FMXTee.Dataset.o
FMXTee.DBChart.o
FMXTee.Editor.Animation.o
FMXTee.Editor.Animations.o
FMXTee.Editor.Aspect.o
FMXTee.Editor.Axis.o
FMXTee.Editor.AxisIncr.o
FMXTee.Editor.AxisMaxMin.o
FMXTee.Editor.Brush.o
FMXTee.Editor.Chart.o
FMXTee.Editor.Chart3D.o
FMXTee.Editor.CrossTab.o
FMXTee.Editor.CustomShape.o
FMXTee.Editor.DB.o
FMXTee.Editor.DBChart.o
FMXTee.Editor.DBSource.o
FMXTee.Editor.DBSummary.o
FMXTee.Editor.Export.Bitmap.o
FMXTee.Editor.Export.o
FMXTee.Editor.FMXAnimations.o
FMXTee.Editor.Font.o
FMXTee.Editor.Formatting.o
FMXTee.Editor.Functions.Average.o
FMXTee.Editor.Functions.Base.o
FMXTee.Editor.Functions.Gallery.o
FMXTee.Editor.Functions.o
FMXTee.Editor.Functions.Period.o
FMXTee.Editor.Gallery.o
FMXTee.Editor.General.o
FMXTee.Editor.Gradient.o
FMXTee.Editor.Legend.o
FMXTee.Editor.Margins.o
FMXTee.Editor.Paging.o
FMXTee.Editor.Panel.o
FMXTee.Editor.Picture.o
FMXTee.Editor.SelectList.o
FMXTee.Editor.Series.Area.o
FMXTee.Editor.Series.Arrow.o
FMXTee.Editor.Series.Bar.Stack.o
FMXTee.Editor.Series.Bubble.o
FMXTee.Editor.Series.Circled.o
FMXTee.Editor.Series.Custom.o
FMXTee.Editor.Series.CustomBar.o
FMXTee.Editor.Series.FastLine.o
FMXTee.Editor.Series.Gantt.o
FMXTee.Editor.Series.o
FMXTee.Editor.Series.Pie.o
FMXTee.Editor.Series.Pointer.o
FMXTee.Editor.Series.Shape.o
FMXTee.Editor.Shadow.o
FMXTee.Editor.Source.o
FMXTee.Editor.Strings.o
FMXTee.Editor.Stroke.o
FMXTee.Editor.Symbol.o
FMXTee.Editor.TextShape.o
FMXTee.Editor.ThreeD.Lights.o
FMXTee.Editor.Title.o
FMXTee.Editor.Tools.o
FMXTee.Editor.Wall.o
FMXTee.Engine.o
FMXTee.Filters.o
FMXTee.Html.o
FMXTee.Print.Preview.o
FMXTee.Print.PreviewPanel.o
FMXTee.Procs.o
FMXTee.RadioGroup.o
FMXTee.Series.Arrow.o
FMXTee.Series.Bubble.o
FMXTee.Series.Gantt.o
FMXTee.Series.o
FMXTee.Series.Shape.o
FMXTee.Series.Spline.o
FMXTee.Store.o
FMXTee.Tools.Gallery.o
FMXTeeChartReg.dcu
FMXTeeChartReg.o
TeeBmps.res
TeeChart.res
TeeDefs.inc
TeeResou.res
Post by Yeray » Tue Dec 24, 2013 10:32 am
It seems the majority of .dcu weren't copied to your destination path. Here is my Delphi19.iOSDevice\Lib:
217 Source Code (Beta)\Sources\compiledStandard\Delphi19.iOSDevice\Lib>dir /b
FMXTee.About.dcu
FMXTee.About.fmx
FMXTee.About.o
FMXTee.Animate.dcu
FMXTee.Animate.o
FMXTee.Animations.dcu
FMXTee.Animations.Gallery.dcu
FMXTee.Animations.Gallery.fmx
FMXTee.Animations.o
FMXTee.Animations.Tools.dcu
FMXTee.Bind.Chart.o
FMXTee.Canvas.dcu
FMXTee.Canvas.o
FMXTee.Chart.Crosstab.dcu
FMXTee.Chart.dcu
FMXTee.Chart.Functions.dcu
FMXTee.Chart.GalleryPanel.dcu
FMXTee.Chart.Grid.dcu
FMXTee.Chart.Grid.o
FMXTee.Chart.ListBox.dcu
FMXTee.Chart.o
FMXTee.Chart3D.dcu
FMXTee.Chart3D.o
FMXTee.Constants.dcu
FMXTee.Constants.o
FMXTee.Dataset.dcu
FMXTee.Dataset.o
FMXTee.DBChart.dcu
FMXTee.DBChart.o
FMXTee.Editor.Animation.dcu
FMXTee.Editor.Animation.fmx
FMXTee.Editor.Animations.dcu
FMXTee.Editor.Animations.fmx
FMXTee.Editor.Aspect.dcu
FMXTee.Editor.Aspect.fmx
FMXTee.Editor.Axis.dcu
FMXTee.Editor.Axis.fmx
FMXTee.Editor.AxisIncr.dcu
FMXTee.Editor.AxisIncr.fmx
FMXTee.Editor.AxisMaxMin.dcu
FMXTee.Editor.AxisMaxMin.fmx
FMXTee.Editor.Brush.dcu
FMXTee.Editor.Brush.fmx
FMXTee.Editor.Chart.dcu
FMXTee.Editor.Chart.fmx
FMXTee.Editor.Chart3D.dcu
FMXTee.Editor.Chart3D.fmx
FMXTee.Editor.CrossTab.dcu
FMXTee.Editor.CrossTab.fmx
FMXTee.Editor.CustomShape.dcu
FMXTee.Editor.CustomShape.fmx
FMXTee.Editor.DB.dcu
FMXTee.Editor.DB.fmx
FMXTee.Editor.DB.o
FMXTee.Editor.DBChart.dcu
FMXTee.Editor.DBChart.fmx
FMXTee.Editor.DBSource.dcu
FMXTee.Editor.DBSource.fmx
FMXTee.Editor.DBSummary.dcu
FMXTee.Editor.DBSummary.fmx
FMXTee.Editor.Export.Bitmap.dcu
FMXTee.Editor.Export.Bitmap.fmx
FMXTee.Editor.Export.dcu
FMXTee.Editor.Export.fmx
FMXTee.Editor.FMXAnimations.dcu
FMXTee.Editor.FMXAnimations.fmx
FMXTee.Editor.Font.dcu
FMXTee.Editor.Font.fmx
FMXTee.Editor.Formatting.dcu
FMXTee.Editor.Formatting.fmx
FMXTee.Editor.Functions.Average.dcu
FMXTee.Editor.Functions.Average.fmx
FMXTee.Editor.Functions.Base.dcu
FMXTee.Editor.Functions.Base.fmx
FMXTee.Editor.Functions.dcu
FMXTee.Editor.Functions.fmx
FMXTee.Editor.Functions.Gallery.dcu
FMXTee.Editor.Functions.Gallery.fmx
FMXTee.Editor.Functions.Period.dcu
FMXTee.Editor.Functions.Period.fmx
FMXTee.Editor.Gallery.dcu
FMXTee.Editor.Gallery.fmx
FMXTee.Editor.General.dcu
FMXTee.Editor.General.fmx
FMXTee.Editor.Gradient.dcu
FMXTee.Editor.Gradient.fmx
FMXTee.Editor.Legend.dcu
FMXTee.Editor.Legend.fmx
FMXTee.Editor.Margins.dcu
FMXTee.Editor.Margins.fmx
FMXTee.Editor.Paging.dcu
FMXTee.Editor.Paging.fmx
FMXTee.Editor.Panel.dcu
FMXTee.Editor.Panel.fmx
FMXTee.Editor.Picture.dcu
FMXTee.Editor.Picture.fmx
FMXTee.Editor.SelectList.dcu
FMXTee.Editor.SelectList.fmx
FMXTee.Editor.Series.Area.dcu
FMXTee.Editor.Series.Area.fmx
FMXTee.Editor.Series.Arrow.dcu
FMXTee.Editor.Series.Arrow.fmx
FMXTee.Editor.Series.Bar.Stack.dcu
FMXTee.Editor.Series.Bar.Stack.fmx
FMXTee.Editor.Series.Bubble.dcu
FMXTee.Editor.Series.Bubble.fmx
FMXTee.Editor.Series.Circled.dcu
FMXTee.Editor.Series.Circled.fmx
FMXTee.Editor.Series.Custom.dcu
FMXTee.Editor.Series.Custom.fmx
FMXTee.Editor.Series.CustomBar.dcu
FMXTee.Editor.Series.CustomBar.fmx
FMXTee.Editor.Series.dcu
FMXTee.Editor.Series.FastLine.dcu
FMXTee.Editor.Series.FastLine.fmx
FMXTee.Editor.Series.fmx
FMXTee.Editor.Series.Gantt.dcu
FMXTee.Editor.Series.Gantt.fmx
FMXTee.Editor.Series.Pie.dcu
FMXTee.Editor.Series.Pie.fmx
FMXTee.Editor.Series.Pointer.dcu
FMXTee.Editor.Series.Pointer.fmx
FMXTee.Editor.Series.Shape.dcu
FMXTee.Editor.Series.Shape.fmx
FMXTee.Editor.Shadow.dcu
FMXTee.Editor.Shadow.fmx
FMXTee.Editor.Source.dcu
FMXTee.Editor.Source.fmx
FMXTee.Editor.Strings.dcu
FMXTee.Editor.Strings.fmx
FMXTee.Editor.Stroke.dcu
FMXTee.Editor.Stroke.fmx
FMXTee.Editor.Symbol.dcu
FMXTee.Editor.Symbol.fmx
FMXTee.Editor.TextShape.dcu
FMXTee.Editor.TextShape.fmx
FMXTee.Editor.ThreeD.Lights.dcu
FMXTee.Editor.ThreeD.Lights.fmx
FMXTee.Editor.Title.dcu
FMXTee.Editor.Title.fmx
FMXTee.Editor.Tools.dcu
FMXTee.Editor.Tools.fmx
FMXTee.Editor.Wall.dcu
FMXTee.Editor.Wall.fmx
FMXTee.Engine.dcu
FMXTee.Engine.o
FMXTee.Filters.dcu
FMXTee.Filters.o
FMXTee.Html.dcu
FMXTee.Html.o
FMXTee.Print.Preview.dcu
FMXTee.Print.Preview.fmx
FMXTee.Print.PreviewPanel.dcu
FMXTee.Procs.dcu
FMXTee.Procs.o
FMXTee.RadioGroup.dcu
FMXTee.RadioGroup.o
FMXTee.Series.Arrow.dcu
FMXTee.Series.Bubble.dcu
FMXTee.Series.dcu
FMXTee.Series.Gantt.dcu
FMXTee.Series.o
FMXTee.Series.Shape.dcu
FMXTee.Series.Spline.dcu
FMXTee.Store.dcu
FMXTee.Store.o
FMXTee.Tools.Gallery.dcu
FMXTee.Tools.Gallery.fmx
FMXTee919.a
FMXTee919.dcp
FMXTee919.o
FMXTee919.res
FMXTeeDB919.a
FMXTeeDB919.dcp
FMXTeeDB919.o
FMXTeeDB919.res
FmxTeeUI919.a
FmxTeeUI919.dcp
FMXTeeUI919.o
FMXTeeUI919.res
Obj
TeeBmps.res
TeeChart.res
TeeDefs.inc
TeeResou.res
makoto
Post by makoto » Tue Dec 24, 2013 10:47 am
Hello.
Yes! and Why?
TeeRecompile error?
Post by Yeray » Tue Dec 24, 2013 12:47 pm
makoto wrote:Hello.
Yes! and Why?
TeeRecompile error?
I'm not sure. You get that message but it continues after it, isn't it?
Here is the log I get for iOS Device.
iOS Device v19 Enterprise (Delphi XE5 and C++Builder XE5 Update 2) (C++)
FMXTee919
79712 lines, 27.27 seconds.
FMXTeeUI919
63912 lines, 78.64 seconds.
FMXTeeDB919
8307 lines, 8.80 seconds.
Binding Units
3397 lines, 6.25 seconds.
VERSION: 2013
Installing...
iOS Device v19 Enterprise (Delphi XE5 and C++Builder XE5 Update 2) (C++) OK. Time: 2m 5s
Have you tried running TeeRecompile again?
makoto
Post by makoto » Wed Dec 25, 2013 1:03 am
Hello.
I tried again.
my environment is Windows7 sp1 Japanese.
TeeChart Standard
Compilation started: 2013/12/25 9:33:02
Tee919
85631 ・s, 1.79 ・b, ・R・[・h 940872 ・o・C・g, ・f・[・^ 4516 ・o・C・g
TeeUI919
78581 ・s, 0.75 ・b, ・R・[・h 609472 ・o・C・g, ・f・[・^ 1364 ・o・C・g
TeeDB919
8408 ・s, 0.28 ・b, ・R・[・h 87412 ・o・C・g, ・f・[・^ 288 ・o・C・g
DclTee919
9150 ・s, 0.86 ・b, ・R・[・h 157988 ・o・C・g, ・f・[・^ 360 ・o・C・g
DclTeeStd919
10156 ・s, 0.39 ・b, ・R・[・h 170152 ・o・C・g, ・f・[・^ 348 ・o・C・g
FMXTee919
79712 ・s, 0.94 ・b, ・R・[・h 883572 ・o・C・g, ・f・[・^ 4144 ・o・C・g
FMXTeeUI919
63912 ・s, 0.59 ・b, ・R・[・h 539068 ・o・C・g, ・f・[・^ 1076 ・o・C・g
FMXTeeDB919
8307 ・s, 0.27 ・b, ・R・[・h 90576 ・o・C・g, ・f・[・^ 288 ・o・C・g
DclFMXTee919
4363 ・s, 0.55 ・b, ・R・[・h 118072 ・o・C・g, ・f・[・^ 268 ・o・C・g
DclFMXTeeStd919
VERSION: 2013
Installing...
Win32 v19 (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 17s
Win64 v19 (Delphi XE5 and C++Builder XE5 Update 2)
Tee919
Embarcadero Delphi for Win64 compiler version 26.0
85631 ・s, 3.25 ・b, ・R・[・h 1443048 ・o・C・g, ・f・[・^ 91068 ・o・C・g
TeeUI919
78581 ・s, 1.39 ・b, ・R・[・h 888824 ・o・C・g, ・f・[・^ 54004 ・o・C・g
TeeDB919
8408 ・s, 0.37 ・b, ・R・[・h 143352 ・o・C・g, ・f・[・^ 8696 ・o・C・g
901 ・s, 1.94 ・b, ・R・[・h 8290 ・o・C・g, ・f・[・^ 732 ・o・C・g
1596 ・s, 0.19 ・b, ・R・[・h 39720 ・o・C・g, ・f・[・^ 5356 ・o・C・g
Binding Units
3394 ・s, 1.09 ・b, ・R・[・h 194878 ・o・C・g, ・f・[・^ 30028 ・o・C・g
FMXTee919
79712 ・s, 2.48 ・b, ・R・[・h 1354632 ・o・C・g, ・f・[・^ 84176 ・o・C・g
FMXTeeUI919
63912 ・s, 1.31 ・b, ・R・[・h 794696 ・o・C・g, ・f・[・^ 45088 ・o・C・g
FMXTeeDB919
8307 ・s, 0.39 ・b, ・R・[・h 149112 ・o・C・g, ・f・[・^ 8804 ・o・C・g
Binding Units
3397 ・s, 1.72 ・b, ・R・[・h 194113 ・o・C・g, ・f・[・^ 30028 ・o・C・g
VERSION: 2013
Installing...
Win64 v19 (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 18s
Mac OSX v19 (Delphi XE5 and C++Builder XE5 Update 2)
FMXTee919
Embarcadero Delphi for Mac OS X compiler version 26.0
79712 ・s, 1.86 ・b, ・R・[・h 1047236 ・o・C・g, ・f・[・^ 383576 ・o・C・g
FMXTeeUI919
63912 ・s, 0.55 ・b, ・R・[・h 533952 ・o・C・g, ・f・[・^ 286724 ・o・C・g
FMXTeeDB919
8307 ・s, 0.30 ・b, ・R・[・h 95708 ・o・C・g, ・f・[・^ 44488 ・o・C・g
Binding Units
3397 ・s, 2.89 ・b, ・R・[・h 207987 ・o・C・g, ・f・[・^ 4 ・o・C・g
VERSION: 2013
Installing...
Mac OSX v19 (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 8s
iOS Simulator v19 (Delphi XE5 and C++Builder XE5 Update 2)
FMXTee919
Embarcadero Delphi Next Generation for iPhone Simulator compiler version 26.0
79712 ・s, 1.39 ・b, ・R・[・h 0 ・o・C・g, ・f・[・^ 0 ・o・C・g
FMXTeeUI919
63912 ・s, 0.48 ・b, ・R・[・h 0 ・o・C・g, ・f・[・^ 0 ・o・C・g
FMXTeeDB919
8307 ・s, 0.25 ・b, ・R・[・h 0 ・o・C・g, ・f・[・^ 0 ・o・C・g
Binding Units
3397 ・s, 2.36 ・b, ・R・[・h 228491 ・o・C・g, ・f・[・^ 4 ・o・C・g
VERSION: 2013
Installing...
iOS Simulator v19 (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 7s
Compiling... unit
153128 ・s・A83.99 ・b・B
Binding Units
73859 ・s・A15.85 ・b・B
VERSION: 2013
Installing...
iOS Device v19 (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 1m 41s
Android v19 (Delphi XE5 and C++Builder XE5 Update 2)
FMXTee919
Embarcadero Delphi for Android compiler version 26.0
79712 ・s・A15.54 ・b・B
FMXTeeUI919
63912 ・s・A53.48 ・b・B
FMXTeeDB919
8307 ・s・A5.99 ・b・B
Binding Units
3397 ・s・A3.98 ・b・B
VERSION: 2013
Installing...
Android v19 (Delphi XE5 and C++Builder XE5 Update 2) OK. Time: 1m 21s
Total time: 234173 msec.
es\compiledStandard\Delphi19.iOSDevice\Lib のディレクトリ
2013/12/25 09:35 <DIR> .
2013/12/25 09:35 <DIR> ..
2013/12/25 09:34 293,340 FMXTee.About.o
2013/12/25 09:35 217,996 FMXTee.Animate.o
2013/12/25 09:35 320,916 FMXTee.Animations.Gallery.o
2013/12/25 09:34 82,632 FMXTee.Animations.o
2013/12/25 09:35 225,304 FMXTee.Animations.Tools.o
2013/12/25 09:35 57,896 FMXTee.Bind.Chart.dcu
2013/12/25 09:35 148,820 FMXTee.Bind.Chart.o
2013/12/25 09:35 187,676 FMXTee.Bind.DBLinks.dcu
2013/12/25 09:35 465,232 FMXTee.Bind.DBLinks.o
2013/12/25 09:35 38,096 FMXTee.Bind.Editors.dcu
2013/12/25 09:35 102,260 FMXTee.Bind.Editors.o
2013/12/25 09:35 486,980 FMXTee.Canvas.o
2013/12/25 09:34 200,412 FMXTee.Chart.Crosstab.o
2013/12/25 09:34 93,728 FMXTee.Chart.Functions.o
2013/12/25 09:34 350,636 FMXTee.Chart.GalleryPanel.o
2013/12/25 09:34 206,040 FMXTee.Chart.Grid.o
2013/12/25 09:34 210,760 FMXTee.Chart.ListBox.o
2013/12/25 09:32 1,592 FMXTee.Chart.ListBox.Style.res
2013/12/25 09:35 821,536 FMXTee.Chart.o
2013/12/25 09:34 325,296 FMXTee.Chart3D.o
2013/12/25 09:35 123,504 FMXTee.Constants.o
2013/12/25 09:34 417,660 FMXTee.Dataset.o
2013/12/25 09:35 295,348 FMXTee.DBChart.o
2013/12/25 09:35 398,044 FMXTee.Editor.Animation.o
2013/12/25 09:35 360,756 FMXTee.Editor.Animations.o
2013/12/25 09:35 464,024 FMXTee.Editor.Aspect.o
2013/12/25 09:34 438,984 FMXTee.Editor.Axis.o
2013/12/25 09:34 282,392 FMXTee.Editor.AxisIncr.o
2013/12/25 09:34 274,600 FMXTee.Editor.AxisMaxMin.o
2013/12/25 09:34 395,824 FMXTee.Editor.Brush.o
2013/12/25 09:35 508,712 FMXTee.Editor.Chart.o
2013/12/25 09:34 396,980 FMXTee.Editor.Chart3D.o
2013/12/25 09:34 283,408 FMXTee.Editor.CrossTab.o
2013/12/25 09:34 300,268 FMXTee.Editor.CustomShape.o
2013/12/25 09:34 324,356 FMXTee.Editor.DB.o
2013/12/25 09:34 388,496 FMXTee.Editor.DBChart.o
2013/12/25 09:34 380,924 FMXTee.Editor.DBSource.o
2013/12/25 09:34 342,844 FMXTee.Editor.DBSummary.o
2013/12/25 09:34 280,268 FMXTee.Editor.Export.Bitmap.o
2013/12/25 09:34 461,392 FMXTee.Editor.Export.o
2013/12/25 09:34 336,776 FMXTee.Editor.FMXAnimations.o
2013/12/25 09:34 299,396 FMXTee.Editor.Font.o
2013/12/25 09:34 298,540 FMXTee.Editor.Formatting.o
2013/12/25 09:34 270,368 FMXTee.Editor.Functions.Average.o
2013/12/25 09:34 270,716 FMXTee.Editor.Functions.Base.o
2013/12/25 09:34 390,456 FMXTee.Editor.Functions.Gallery.o
2013/12/25 09:34 345,124 FMXTee.Editor.Functions.o
2013/12/25 09:34 279,348 FMXTee.Editor.Functions.Period.o
2013/12/25 09:34 481,348 FMXTee.Editor.Gallery.o
2013/12/25 09:34 485,308 FMXTee.Editor.General.o
2013/12/25 09:34 405,808 FMXTee.Editor.Gradient.o
2013/12/25 09:34 364,852 FMXTee.Editor.Legend.o
2013/12/25 09:34 275,328 FMXTee.Editor.Margins.o
2013/12/25 09:34 337,836 FMXTee.Editor.Paging.o
2013/12/25 09:34 293,036 FMXTee.Editor.Panel.o
2013/12/25 09:34 291,552 FMXTee.Editor.Picture.o
2013/12/25 09:34 280,032 FMXTee.Editor.SelectList.o
2013/12/25 09:35 300,824 FMXTee.Editor.Series.Area.o
2013/12/25 09:35 281,544 FMXTee.Editor.Series.Arrow.o
2013/12/25 09:35 275,824 FMXTee.Editor.Series.Bar.Stack.o
2013/12/25 09:35 269,024 FMXTee.Editor.Series.Bubble.o
2013/12/25 09:35 292,392 FMXTee.Editor.Series.Circled.o
2013/12/25 09:35 308,500 FMXTee.Editor.Series.Custom.o
2013/12/25 09:35 421,868 FMXTee.Editor.Series.CustomBar.o
2013/12/25 09:35 279,704 FMXTee.Editor.Series.FastLine.o
2013/12/25 09:35 276,716 FMXTee.Editor.Series.Gantt.o
2013/12/25 09:34 477,840 FMXTee.Editor.Series.o
2013/12/25 09:35 310,956 FMXTee.Editor.Series.Pie.o
2013/12/25 09:34 404,852 FMXTee.Editor.Series.Pointer.o
2013/12/25 09:35 287,760 FMXTee.Editor.Series.Shape.o
2013/12/25 09:34 284,572 FMXTee.Editor.Shadow.o
2013/12/25 09:34 342,300 FMXTee.Editor.Source.o
2013/12/25 09:34 274,004 FMXTee.Editor.Strings.o
2013/12/25 09:34 353,348 FMXTee.Editor.Stroke.o
2013/12/25 09:34 281,812 FMXTee.Editor.Symbol.o
2013/12/25 09:34 285,156 FMXTee.Editor.TextShape.o
2013/12/25 09:34 297,644 FMXTee.Editor.ThreeD.Lights.o
2013/12/25 09:34 281,280 FMXTee.Editor.Title.o
2013/12/25 09:34 345,604 FMXTee.Editor.Tools.o
2013/12/25 09:34 285,508 FMXTee.Editor.Wall.o
2013/12/25 09:35 1,293,312 FMXTee.Engine.o
2013/12/25 09:35 220,168 FMXTee.Filters.o
2013/12/25 09:35 41,660 FMXTee.Html.o
2013/12/25 09:34 294,428 FMXTee.Print.Preview.o
2013/12/25 09:34 156,736 FMXTee.Print.PreviewPanel.o
2013/12/25 09:35 536,188 FMXTee.Procs.o
2013/12/25 09:34 82,100 FMXTee.RadioGroup.o
2013/12/25 09:35 34,760 FMXTee.Series.Arrow.o
2013/12/25 09:35 30,472 FMXTee.Series.Bubble.o
2013/12/25 09:35 33,864 FMXTee.Series.Gantt.o
2013/12/25 09:35 617,804 FMXTee.Series.o
2013/12/25 09:35 48,040 FMXTee.Series.Shape.o
2013/12/25 09:35 75,268 FMXTee.Series.Spline.o
2013/12/25 09:34 145,464 FMXTee.Store.o
2013/12/25 09:34 408,988 FMXTee.Tools.Gallery.o
2013/12/25 09:35 2,172 FMXTeeChartReg.dcu
2013/12/25 09:35 49,296 FMXTeeChartReg.o
2013/12/25 09:32 7,108 TeeBmps.res
2013/12/25 09:32 43,824 TeeChart.res
2013/12/25 09:32 8,798 TeeDefs.inc
2013/12/25 09:32 12,984 TeeResou.res
101 個のファイル 29,024,222 バイト
2 個のディレクトリ 79,250,984,960 バイトの空き領域
Post by Pep » Fri Dec 27, 2013 10:14 am
so, if I understand, all is working fine now ? As I can see you don't get any error message by using the TeeRecompile tool.
makoto
Post by makoto » Mon Dec 30, 2013 4:04 am
Hello.
I think ".dcu" file is missing.
and error "FMXTee.Editor.DBChart.pas(200)".
I could not decipher the error message.
Compiling... unit
Binding Units
VERSION: 2013
Installing...
Post by Pep » Mon Dec 30, 2013 10:37 am
I've just sent to you a private mail related to this post, so you can check if the problem has been solved to you with the latest installer.
makoto
Post by makoto » Sun Jan 05, 2014 4:10 am
Hello.
I tried!
TeeRecompile was successful.
And TChart iOS Device was working properly.
Thank you!!
