Trying to implement panning/scroling
cjacoby78
Post by cjacoby78 » Sun Jun 29, 2014 5:15 pm
Hi all.
As I want more control about panning, and as the default panning provided doesn't work well, I tried to implement panning myself using gestures in FireMonkey. Here is what I got so far for the X axis only:
procedure TMultiEPGFrame.FrameGesture(Sender: TObject;
  const EventInfo: TGestureEventInfo; var Handled: Boolean);
var
  lGlobalWidth: Double;
  lLocalWidth: Double;
  if EventInfo.GestureID = igiPan then
    lGlobalWidth := self.Width;
    lLocalWidth := fChart.BottomAxis.Maximum - fChart.BottomAxis.Minimum;
    if fLastPosition.X < EventInfo.Location.X then
      fChart.BottomAxis.Minimum := fChart.BottomAxis.Minimum -
        ((EventInfo.Location.X) / lGlobalWidth);
      fChart.BottomAxis.Maximum := fChart.BottomAxis.Maximum -
    end
      fChart.BottomAxis.Minimum := fChart.BottomAxis.Minimum +
      fChart.BottomAxis.Maximum := fChart.BottomAxis.Maximum +
    fLastPosition := EventInfo.Location;
I basically adjust the maximum and minimum of my X axis approximately by the amount my finger goes left or right ... If anyone has a better suggestion, I am all ears!
Thanks a lot!
CJ
Re: Trying to implement panning/scroling
Post by Yeray » Tue Jul 01, 2014 10:57 am
Hi CJ,
This seems to be related to this thread.
As Pep said there, setting the Left button as the ScrollMouseButton should make the default scoll feature usable in mobile applications.
cjacoby78
Post by cjacoby78 » Tue Jul 01, 2014 5:58 pm
Yes, thanks this works - one more question though also asked in the other thread:
How do I block panning/scrolling to work inside some arbitrary bounds only?
Cheers,
CJ
cjacoby78
Post by cjacoby78 » Tue Jul 01, 2014 8:57 pm
This is a solution I implemented which works:
http://www.teechart.net/support/viewtop ... 661#p66661
Post by Yeray » Wed Jul 02, 2014 7:22 am
Hi CJ,
We'll reply you in the other thread as soon as possible.
There's no need to maintain two threads with the same questions and answers.
