TTeeCommander button bitmaps cut
X-Ray
Post by X-Ray » Wed Nov 26, 2014 10:59 am
I am using a TTeeCommander component in an iOS project.
But somehow the buttons/bitmaps are always cut on the bottom of
TeeCommander toolbar, like in the attached screen shot.
Is there any way to correctly display these button?
Re: TTeeCommander button bitmaps cut
Post by Yeray » Thu Nov 27, 2014 9:01 am
Have you tried to resize it?
Does it happen in the simulator or only in a real device?
Also note the editor/commander have been designed to help the developer to build and test their applications. These tools aren't designed to be accessed by the final users, so we don't recommend giving access to it.
X-Ray
Post by X-Ray » Thu Nov 27, 2014 9:34 am
Hello Yeray,
Yes, I tried to re-size it but it doesn't help. And the display is the same on the simulator too.
What is the recommended way to bind own toolbar buttons to the same functions?
X-Ray
Post by X-Ray » Tue Dec 02, 2014 2:24 pm
Hello Yeray,
It would be very nice if there were simply a set of actions available that I could use to link any UI element to those functions that are available on the TTeeCommander toolbar.
Post by Yeray » Wed Dec 03, 2014 1:57 pm
Here you have what the buttons in the commander actually do:
procedure TTeeCommander.ButtonNormalClick(Sender: TObject);
var tmp : TCircledSeries;
  tmp:=GetCircledSeries(0,0);
  if Assigned(tmp) and tmp.Visible then
     SetLabelCaption(CaptionPanel(TeeCommanMsg_NormalPieLabel))
     SetLabelCaption(CaptionPanel(TeeCommanMsg_NormalLabel));
  {$IFDEF FMX}
  if Assigned(ButtonNormal) then
     ButtonNormal.Down:=True;
  {$ENDIF}
procedure TTeeCommander.ButtonRotateClick(Sender: TObject);
  SetLabelCaption(CaptionPanel(TeeCommanMsg_RotateLabel));
  {$IFDEF FMX}
  if Assigned(ButtonRotate) then
     ButtonRotate.Down:=True;
  {$ENDIF}
procedure TTeeCommander.ButtonMoveClick(Sender: TObject);
  SetLabelCaption(CaptionPanel(TeeCommanMsg_MoveLabel));
  {$IFDEF FMX}
  if Assigned(ButtonMove) then
     ButtonMove.Down:=True;
  {$ENDIF}
procedure TTeeCommander.ButtonZoomClick(Sender: TObject);
  SetLabelCaption(CaptionPanel(TeeCommanMsg_ZoomLabel));
  {$IFDEF FMX}
  if Assigned(ButtonZoom) then
     ButtonZoom.Down:=True;
  {$ENDIF}
procedure TTeeCommander.ButtonDepthClick(Sender: TObject);
  SetLabelCaption(CaptionPanel(TeeCommanMsg_DepthLabel));
  {$IFDEF FMX}
  if Assigned(ButtonDepth) then
     ButtonDepth.Down:=True;
  {$ENDIF}
procedure TTeeCommander.Button3DClick(Sender: TObject);
  if Assigned(FPanel) then
    {$IFDEF CLX}
    IChanging3D:=True;
    {$ENDIF}
    FPanel.View3D:={$IFDEF CLX}not {$ENDIF}FButton3D.Down;
    {$IFDEF CLX}
    IChanging3D:=False;
    {$ENDIF}
procedure TTeeCommander.ButtonEditClick(Sender: TObject);
{$IFNDEF TEEOCXNOEDITOR}
var tmp : TCustomTeePanel;
{$ENDIF}
  tmp:=nil;
  if Assigned(FEditor) then
     FEditor.Execute
    tmp:=TTeePanelAccess(FPanel).GetEditablePanel;
    if tmp is TCustomChart then
       {$IFDEF FMX}
       TChartEditForm.Edit(nil,TCustomChart(tmp))
       {$ELSE}
       {$IFDEF TEEOCX}
       EditChart(self,TCustomChart(tmp)) //TA05015162
       {$ELSE}
       EditChart(nil,TCustomChart(tmp))
       {$ENDIF}
       {$ENDIF}
    if tmp is TCustomTeePanelExtended then
       {$IFDEF FMX}
       TGradientEditor.Edit(nil,TCustomTeePanelExtended(tmp).Gradient);
       {$ELSE}
       EditTeeGradient(nil,TCustomTeePanelExtended(tmp).Gradient);
       {$ENDIF}
  if Assigned(FOnEditedChart) then
     if Assigned(tmp) and (tmp is TCustomChart) then
        FOnEditedChart(Self,TCustomChart(tmp));
  if Assigned(FButton3D) then
     FButton3D.Down:=FPanel.View3D;
  {$ENDIF}
procedure TTeeCommander.ButtonPrintClick(Sender: TObject);
  if Assigned(FPreviewer) then FPreviewer.Execute
     {$IFDEF FMX}
     TChartPreview.Preview(nil, FPanel);
     {$ELSE}
     {$IFDEF TEEOCX}
     ChartPreview(self,FPanel); //TA05015162
     {$ELSE}
     ChartPreview(nil,FPanel);
     {$ENDIF}
     {$ENDIF}
  {$ENDIF}
procedure TTeeCommander.ButtonCopyClick(Sender: TObject);
  if Assigned(FPanel) then FPanel.CopyToClipboardBitmap;
procedure TTeeCommander.ButtonSaveClick(Sender: TObject);
     if FPanel is TCustomChart then
        SaveChartDialog(FPanel as TCustomChart);
  {$ENDIF}
X-Ray
Post by X-Ray » Wed Dec 03, 2014 3:57 pm
Hello Yeray,
but call "SetLabelCaption" is private of "TTeeCommander" so I can't use this call in my code.
Or did you think about another way?
Post by Yeray » Thu Dec 04, 2014 10:58 am
X-Ray wrote:but call "SetLabelCaption" is private of "TTeeCommander" so I can't use this call in my code.
I posted the relevant methods for you to have an idea about what they actually do.
I believe you own the TeeChart sources so there's no need to put here the complete TeeComma.pas unit.
X-Ray
Post by X-Ray » Thu Dec 04, 2014 11:17 am
Hello Yeray,
yes of course, but that would mean duplicating all the code in there!
It would be much more elegant to offer this functionality via Actions, this would remove all the
necessity to know about internals and to duplicate any code.
Post by Yeray » Fri Dec 05, 2014 10:36 am
X-Ray wrote:yes of course, but that would mean duplicating all the code in there!
Sorry, I understood you wanted to put your own buttons doing the same the buttons on the commander do. I don't see how this could be done without repeating some code.
I may have misunderstood you.
