Android - Memory increase - Repaint
Duke
Post by Duke » Fri Apr 26, 2019 10:38 am
TeeChart VCL/FMX Source version 2018 - Build 2018.26.181203
Delphi 10.2.3
- new FMX Project
- adding TChart
- adding Series/FastLine
- adding Timer with "Chart1.invalidate"
= Android shows rapid meory increase. Memory leak ?
Testet on Samsung Tablet (new), Samsung Mobile (older)
No problems with Windows.
Problem appeared by updating a TLabel with new Text in front of the Chart.
Thank You
Re: Android - Memory increase - Repaint
Post by Yeray » Tue Apr 30, 2019 9:00 am
How are you monitoring the memory consumption?
Please arrange a simple example project we can run as-is to reproduce the problem here.
Duke
Post by Duke » Thu May 02, 2019 8:30 am
Ok.
I got a "out of memory" exception in my Project after 40 minutes. I check the memory in Android with the standard memory usage display in settings.
AndroidMemoryTest.zip
(9.29 KiB) Downloaded 1091 times
Duke
Post by Duke » Fri May 10, 2019 12:18 pm
Hi, we still have this issue. Why does no one else has this Problem?
also with Delphi 10.3, installed on a different computer we have a similar problem, where TChart blocks the view update from the complete Form.
Post by Yeray » Tue May 14, 2019 8:47 am
I've been able to see the memory leak in the system configuration, as you suggested, but I'm afraid haven't been able to find the cause of it so far.
I've tried to use LeakCheck and FastMM4 (this one targeting win32) to identify the memory leak without success.
I've been running the tests with 10.3 Rio.
I'll give a try at 10.2 Tokyo and let you know what I get.
Post by Yeray » Tue May 14, 2019 12:45 pm
As far as I can see, I can't get much further with LeakCheck. I get this:
And this:
https://i.imgur.com/6pnb0Ti.mp4
05-14 14:17:08.094 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 AA 9C 08 D6 75 00 00 00 B0 C2 D1 D6 B0 47 F2 D4 00 00 00 00 00 00 00 00 | ?y??????????u????????G??????????
05-14 14:17:08.096 22707 22707 W leak    :   B9 9C 08 D6 38 9B 50 D4 90 07 08 D6 13 00 00 00 01 00 00 00 | ????8?P?????????????
05-14 14:17:08.097 22707 22707 W leak    : Leak detected D4509B30 size 16 B
05-14 14:17:08.098 22707 22707 W leak    :   01 00 00 00 02 00 00 00 30 AF 50 D4 30 B4 50 D4 | ????????0?P?0?P?
05-14 14:17:08.100 22707 22707 W leak    : Leak detected D450A7B0 size 44 B
05-14 14:17:08.101 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 BC 9C 08 D6 1A 00 00 00 B0 C2 D1 D6 30 A5 50 D4 00 00 00 00 BC AC 50 D4 | ?x??????????????????0?P???????P?
05-14 14:17:08.102 22707 22707 W leak    :   08 00 00 00 F8 99 08 D6 00 00 00 00 | ????????????
05-14 14:17:08.104 22707 22707 W leak    : Leak detected D450ACB0 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.105 22707 22707 W leak    : Leak detected D450AF30 size 44 B
05-14 14:17:08.106 22707 22707 W leak    :   CC 78 F1 D5 02 00 00 00 D6 9C 08 D6 16 00 00 00 B0 C2 D1 D6 30 A5 50 D4 00 00 00 00 BC B1 50 D4 | ?x??????????????????0?P???????P?
05-14 14:17:08.108 22707 22707 W leak    :   00 00 00 00 C8 72 EC D5 00 00 00 00 | ?????r??????
05-14 14:17:08.109 22707 22707 W leak    : Leak detected D450B1B0 size 26 B for UnicodeString {RefCount: 1} = cookie
05-14 14:17:08.110 22707 22707 W leak    : Leak detected D450B430 size 44 B
05-14 14:17:08.112 22707 22707 W leak    :   CC 78 F1 D5 02 00 00 00 EC 9C 08 D6 18 00 00 00 B0 C2 D1 D6 30 A5 50 D4 00 00 00 00 BC B6 50 D4 | ?x??????????????????0?P???????P?
05-14 14:17:08.113 22707 22707 W leak    :   08 00 00 00 64 DE F9 D5 00 00 00 00 | ????d???????
05-14 14:17:08.114 22707 22707 W leak    : Leak detected D450B6B0 size 30 B for UnicodeString {RefCount: 1} = fileName
05-14 14:17:08.116 22707 22707 W leak    : Leak detected D450B930 size 52 B
05-14 14:17:08.117 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 1F 9D 08 D6 64 00 00 00 B0 C2 D1 D6 B0 47 F2 D4 00 00 00 00 00 00 00 00 | ?y??????????d????????G??????????
05-14 14:17:08.118 22707 22707 W leak    :   35 9D 08 D6 38 AA 50 D4 D4 FE 0A D6 14 00 00 00 01 00 00 00 | 5???8?P?????????????
05-14 14:17:08.119 22707 22707 W leak    : Leak detected D450AA30 size 12 B
05-14 14:17:08.121 22707 22707 W leak    :   01 00 00 00 01 00 00 00 30 C3 50 D4 | ????????0?P?
05-14 14:17:08.122 22707 22707 W leak    : Leak detected D450BBB0 size 44 B
05-14 14:17:08.123 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 38 9D 08 D6 1A 00 00 00 B0 C2 D1 D6 30 B9 50 D4 00 00 00 00 BC C0 50 D4 | ?x??????8???????????0?P???????P?
05-14 14:17:08.124 22707 22707 W leak    :   08 00 00 00 F8 99 08 D6 00 00 00 00 | ????????????
05-14 14:17:08.126 22707 22707 W leak    : Leak detected D450C0B0 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.127 22707 22707 W leak    : Leak detected D450C330 size 44 B
05-14 14:17:08.128 22707 22707 W leak    :   CC 78 F1 D5 02 00 00 00 52 9D 08 D6 18 00 00 00 B0 C2 D1 D6 30 B9 50 D4 00 00 00 00 BC C5 50 D4 | ?x??????R???????????0?P???????P?
05-14 14:17:08.129 22707 22707 W leak    :   08 00 00 00 64 DE F9 D5 00 00 00 00 | ????d???????
05-14 14:17:08.131 22707 22707 W leak    : Leak detected D450C5B0 size 30 B for UnicodeString {RefCount: 1} = fileName
05-14 14:17:08.132 22707 22707 W leak    : Leak detected D450C830 size 52 B
05-14 14:17:08.133 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 83 9D 08 D6 7A 00 00 00 B0 C2 D1 D6 B0 47 F2 D4 00 00 00 00 00 00 00 00 | ?y??????????z????????G??????????
05-14 14:17:08.134 22707 22707 W leak    :   99 9D 08 D6 38 BE 50 D4 D4 FE 0A D6 15 00 00 00 01 00 00 00 | ????8?P?????????????
05-14 14:17:08.136 22707 22707 W leak    : Leak detected D450BE30 size 16 B
05-14 14:17:08.137 22707 22707 W leak    :   01 00 00 00 02 00 00 00 30 D2 50 D4 30 D7 50 D4 | ????????0?P?0?P?
05-14 14:17:08.138 22707 22707 W leak    : Leak detected D450CAB0 size 44 B
05-14 14:17:08.139 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 9C 9D 08 D6 1A 00 00 00 B0 C2 D1 D6 30 C8 50 D4 00 00 00 00 BC CF 50 D4 | ?x??????????????????0?P???????P?
05-14 14:17:08.141 22707 22707 W leak    :   08 00 00 00 F8 99 08 D6 00 00 00 00 | ????????????
05-14 14:17:08.142 22707 22707 W leak    : Leak detected D450CFB0 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.143 22707 22707 W leak    : Leak detected D450D230 size 44 B
05-14 14:17:08.144 22707 22707 W leak    :   CC 78 F1 D5 02 00 00 00 B6 9D 08 D6 16 00 00 00 B0 C2 D1 D6 30 C8 50 D4 00 00 00 00 BC D4 50 D4 | ?x??????????????????0?P???????P?
05-14 14:17:08.146 22707 22707 W leak    :   00 00 00 00 C8 72 EC D5 00 00 00 00 | ?????r??????
05-14 14:17:08.147 22707 22707 W leak    : Leak detected D450D4B0 size 26 B for UnicodeString {RefCount: 1} = cookie
05-14 14:17:08.148 22707 22707 W leak    : Leak detected D450D730 size 44 B
05-14 14:17:08.149 22707 22707 W leak    :   CC 78 F1 D5 02 00 00 00 CC 9D 08 D6 18 00 00 00 B0 C2 D1 D6 30 C8 50 D4 00 00 00 00 BC D9 50 D4 | ?x??????????????????0?P???????P?
05-14 14:17:08.151 22707 22707 W leak    :   08 00 00 00 64 DE F9 D5 00 00 00 00 | ????d???????
05-14 14:17:08.152 22707 22707 W leak    : Leak detected D450D9B0 size 30 B for UnicodeString {RefCount: 1} = fileName
05-14 14:17:08.153 22707 22707 W leak    : Leak detected D450DC30 size 32 B
05-14 14:17:08.154 22707 22707 W leak    :   C0 13 F1 D5 01 00 00 00 CC 92 EC D5 C4 DE 50 D4 B8 FC 50 D4 00 00 00 00 20 13 F1 D5 00 00 00 00 | ??????????????P???P????? ???????
05-14 14:17:08.156 22707 22707 W leak    : Leak detected D450DEB0 size 28 B
05-14 14:17:08.157 22707 22707 W leak    :   08 A9 F0 D5 01 00 00 00 CC 92 EC D5 38 E1 50 D4 01 00 00 00 68 A8 F0 D5 00 00 00 00 | ????????????8?P?????h???????
05-14 14:17:08.158 22707 22707 W leak    : Leak detected D450F030 size 78 B for UnicodeString {RefCount: 2} = android/content/res/AssetManager
05-14 14:17:08.160 22707 22707 W leak    : Leak detected D450F7B0 size 16 B
05-14 14:17:08.161 22707 22707 W leak    :   C4 55 F8 D5 02 00 00 00 3C F0 50 D4 00 00 00 00 | ?U??????<?P?????
05-14 14:17:08.162 22707 22707 W leak    : Leak detected D450FCB0 size 12 B
05-14 14:17:08.163 22707 22707 W leak    :   01 00 00 00 01 00 00 00 B0 F7 50 D4 | ??????????P?
05-14 14:17:08.165 22707 22707 W leak    : Leak detected D450E130 size 24 B
05-14 14:17:08.166 22707 22707 W leak    :   01 00 00 00 04 00 00 00 B0 F7 50 D4 00 00 00 00 00 00 00 00 00 00 00 00 | ??????????P?????????????
05-14 14:17:08.167 22707 22707 W leak    : Leak detected D45FF5B0 size 40 B
05-14 14:17:08.169 22707 22707 W leak    :   74 E7 EF D5 01 00 00 00 84 17 FA D5 6D 0A 00 00 B0 C2 D1 D6 00 00 00 00 C8 AA 52 D4 38 2F 05 E7 | t???????????m?????????????R?8/??
05-14 14:17:08.170 22707 22707 W leak    :   38 00 00 00 01 00 00 00 | 8???????
05-14 14:17:08.171 22707 22707 W leak    : Leak detected E7052F30 size 184 B
05-14 14:17:08.172 22707 22707 W leak    :   01 00 00 00 2C 00 00 00 30 FA 50 D4 B0 ED 50 D4 30 FF 50 D4 B0 06 51 D4 B0 15 51 D4 30 1D 51 D4 | ????,???0?P???P?0?P???Q???Q?0?Q?
05-14 14:17:08.174 22707 22707 W leak    :   B0 24 51 D4 30 2C 51 D4 30 3B 51 D4 B0 42 51 D4 30 4A 51 D4 B0 51 51 D4 30 59 51 D4 B0 60 51 D4 | ?$Q?0,Q?0;Q??BQ?0JQ??QQ?0YQ??`Q?
05-14 14:17:08.175 22707 22707 W leak    :   30 68 51 D4 B0 6F 51 D4 30 77 51 D4 B0 7E 51 D4 30 86 51 D4 B0 8D 51 D4 30 95 51 D4 B0 9C 51 D4 | 0hQ??oQ?0wQ??~Q?0?Q???Q?0?Q???Q?
05-14 14:17:08.176 22707 22707 W leak    :   30 A4 51 D4 B0 AB 51 D4 30 B3 51 D4 B0 BA 51 D4 30 C2 51 D4 B0 C9 51 D4 30 D1 51 D4 30 E0 51 D4 | 0?Q???Q?0?Q???Q?0?Q???Q?0?Q?0?Q?
05-14 14:17:08.178 22707 22707 W leak    :   B0 E7 51 D4 B0 F6 51 D4 B0 05 52 D4 30 0D 52 D4 B0 14 52 D4 B0 23 52 D4 B0 37 52 D4 B0 46 52 D4 | ??Q???Q???R?0?R???R??#R??7R??FR?
05-14 14:17:08.179 22707 22707 W leak    :   B0 55 52 D4 30 5D 52 D4 30 71 52 D4 30 80 52 D4 30 94 52 D4 30 A3 52 D4 | ?UR?0]R?0qR?0?R?0?R?0?R?
05-14 14:17:08.180 22707 22707 W leak    : Leak detected D450FA30 size 52 B
05-14 14:17:08.182 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 BD 17 FA D5 2E 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????.?????????_?????????
05-14 14:17:08.183 22707 22707 W leak    :   C8 17 FA D5 00 00 00 00 3A 72 EC D5 0C 00 00 00 01 00 00 00 | ????????:r??????????
05-14 14:17:08.184 22707 22707 W leak    : Leak detected D450E630 size 44 B
05-14 14:17:08.185 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 CB 17 FA D5 12 00 00 00 B0 C2 D1 D6 30 FA 50 D4 00 00 00 00 3C EB 50 D4 | ?x??????????????????0?P?????<?P?
05-14 14:17:08.187 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.188 22707 22707 W leak    : Leak detected D450EB30 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.189 22707 22707 W leak    : Leak detected D450EDB0 size 52 B
05-14 14:17:08.190 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 EB 17 FA D5 2B 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????+?????????_?????????
05-14 14:17:08.192 22707 22707 W leak    :   F3 17 FA D5 00 00 00 00 3A 72 EC D5 0D 00 00 00 01 00 00 00 | ????????:r??????????
05-14 14:17:08.193 22707 22707 W leak    : Leak detected D450E8B0 size 44 B
05-14 14:17:08.194 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 F6 17 FA D5 12 00 00 00 B0 C2 D1 D6 B0 ED 50 D4 00 00 00 00 3C F5 50 D4 | ?x????????????????????P?????<?P?
05-14 14:17:08.195 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.197 22707 22707 W leak    : Leak detected D450F530 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.198 22707 22707 W leak    : Leak detected D450FF30 size 52 B
05-14 14:17:08.199 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 16 18 FA D5 2C 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????,?????????_?????????
05-14 14:17:08.201 22707 22707 W leak    :   1F 18 FA D5 00 00 00 00 3A 72 EC D5 0E 00 00 00 01 00 00 00 | ????????:r??????????
05-14 14:17:08.202 22707 22707 W leak    : Leak detected D450F2B0 size 44 B
05-14 14:17:08.203 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 22 18 FA D5 12 00 00 00 B0 C2 D1 D6 30 FF 50 D4 00 00 00 00 3C 04 51 D4 | ?x??????"???????????0?P?????<?Q?
05-14 14:17:08.204 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.206 22707 22707 W leak    : Leak detected D4510430 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.207 22707 22707 W leak    : Leak detected D45106B0 size 52 B
05-14 14:17:08.208 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 42 18 FA D5 42 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????B???B?????????_?????????
05-14 14:17:08.209 22707 22707 W leak    :   4C 18 FA D5 B8 01 51 D4 CC 72 EC D5 0F 00 00 00 01 00 00 00 | L?????Q??r??????????
05-14 14:17:08.211 22707 22707 W leak    : Leak detected D45101B0 size 12 B
05-14 14:17:08.212 22707 22707 W leak    :   01 00 00 00 01 00 00 00 B0 10 51 D4 | ??????????Q?
05-14 14:17:08.213 22707 22707 W leak    : Leak detected D4510930 size 44 B
05-14 14:17:08.214 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 4F 18 FA D5 12 00 00 00 B0 C2 D1 D6 B0 06 51 D4 00 00 00 00 3C 0E 51 D4 | ?x??????O?????????????Q?????<?Q?
05-14 14:17:08.216 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.217 22707 22707 W leak    : Leak detected D4510E30 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.218 22707 22707 W leak    : Leak detected D45110B0 size 44 B
05-14 14:17:08.219 22707 22707 W leak    :   CC 78 F1 D5 02 00 00 00 61 18 FA D5 15 00 00 00 B0 C2 D1 D6 B0 06 51 D4 00 00 00 00 3C 13 51 D4 | ?x??????a?????????????Q?????<?Q?
05-14 14:17:08.220 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.222 22707 22707 W leak    : Leak detected D4511330 size 28 B for UnicodeString {RefCount: 1} = another
05-14 14:17:08.223 22707 22707 W leak    : Leak detected D45115B0 size 52 B
05-14 14:17:08.224 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 84 18 FA D5 31 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????1?????????_?????????
05-14 14:17:08.225 22707 22707 W leak    :   92 18 FA D5 00 00 00 00 3A 72 EC D5 10 00 00 00 01 00 00 00 | ????????:r??????????
05-14 14:17:08.227 22707 22707 W leak    : Leak detected D4510BB0 size 44 B
05-14 14:17:08.228 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 95 18 FA D5 12 00 00 00 B0 C2 D1 D6 B0 15 51 D4 00 00 00 00 BC 1A 51 D4 | ?x????????????????????Q???????Q?
05-14 14:17:08.229 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.230 22707 22707 W leak    : Leak detected D4511AB0 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.232 22707 22707 W leak    : Leak detected D4511D30 size 52 B
05-14 14:17:08.233 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 B5 18 FA D5 2A 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????*?????????_?????????
05-14 14:17:08.234 22707 22707 W leak    :   BC 18 FA D5 00 00 00 00 3A 72 EC D5 11 00 00 00 01 00 00 00 | ????????:r??????????
05-14 14:17:08.236 22707 22707 W leak    : Leak detected D4511830 size 44 B
05-14 14:17:08.237 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 BF 18 FA D5 12 00 00 00 B0 C2 D1 D6 30 1D 51 D4 00 00 00 00 3C 22 51 D4 | ?x??????????????????0?Q?????<"Q?
05-14 14:17:08.239 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.240 22707 22707 W leak    : Leak detected D4512230 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.241 22707 22707 W leak    : Leak detected D45124B0 size 52 B
05-14 14:17:08.243 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 DF 18 FA D5 24 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????$?????????_?????????
05-14 14:17:08.244 22707 22707 W leak    :   EC 18 FA D5 00 00 00 00 00 00 00 00 12 00 00 00 01 00 00 00 | ????????????????????
05-14 14:17:08.245 22707 22707 W leak    : Leak detected D4511FB0 size 44 B
05-14 14:17:08.246 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 EF 18 FA D5 12 00 00 00 B0 C2 D1 D6 B0 24 51 D4 00 00 00 00 BC 29 51 D4 | ?x???????????????????$Q??????)Q?
05-14 14:17:08.248 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.249 22707 22707 W leak    : Leak detected D45129B0 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.250 22707 22707 W leak    : Leak detected D4512C30 size 52 B
05-14 14:17:08.251 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 03 19 FA D5 3D 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????=?????????_?????????
05-14 14:17:08.252 22707 22707 W leak    :   0A 19 FA D5 38 27 51 D4 3A 72 EC D5 13 00 00 00 01 00 00 00 | ????8'Q?:r??????????
05-14 14:17:08.254 22707 22707 W leak    : Leak detected D4512730 size 12 B
05-14 14:17:08.255 22707 22707 W leak    :   01 00 00 00 01 00 00 00 30 36 51 D4 | ????????06Q?
05-14 14:17:08.256 22707 22707 W leak    : Leak detected D4512EB0 size 44 B
05-14 14:17:08.258 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 0D 19 FA D5 12 00 00 00 B0 C2 D1 D6 30 2C 51 D4 00 00 00 00 BC 33 51 D4 | ?x??????????????????0,Q??????3Q?
05-14 14:17:08.259 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.260 22707 22707 W leak    : Leak detected D45133B0 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.261 22707 22707 W leak    : Leak detected D4513630 size 44 B
05-14 14:17:08.262 22707 22707 W leak    :   CC 78 F1 D5 02 00 00 00 1F 19 FA D5 13 00 00 00 B0 C2 D1 D6 30 2C 51 D4 00 00 00 00 BC 38 51 D4 | ?x??????????????????0,Q??????8Q?
05-14 14:17:08.263 22707 22707 W leak    :   08 00 00 00 94 CD F9 D5 00 00 00 00 | ????????????
05-14 14:17:08.265 22707 22707 W leak    : Leak detected D45138B0 size 20 B for UnicodeString {RefCount: 1} = obj
05-14 14:17:08.266 22707 22707 W leak    : Leak detected D4513B30 size 52 B
05-14 14:17:08.267 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 40 19 FA D5 2A 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????@???*?????????_?????????
05-14 14:17:08.268 22707 22707 W leak    :   47 19 FA D5 00 00 00 00 3A 72 EC D5 14 00 00 00 01 00 00 00 | G???????:r??????????
05-14 14:17:08.269 22707 22707 W leak    : Leak detected D4513130 size 44 B
05-14 14:17:08.271 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 4A 19 FA D5 12 00 00 00 B0 C2 D1 D6 30 3B 51 D4 00 00 00 00 3C 40 51 D4 | ?x??????J???????????0;Q?????<@Q?
05-14 14:17:08.272 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.273 22707 22707 W leak    : Leak detected D4514030 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.275 22707 22707 W leak    : Leak detected D45142B0 size 52 B
05-14 14:17:08.276 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 6A 19 FA D5 31 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????j???1?????????_?????????
05-14 14:17:08.277 22707 22707 W leak    :   7A 19 FA D5 00 00 00 00 84 17 FA D5 15 00 00 00 01 00 00 00 | z???????????????????
05-14 14:17:08.278 22707 22707 W leak    : Leak detected D4513DB0 size 44 B
05-14 14:17:08.279 22707 22707 W leak    :   CC 78 F1 D5 01 00 00 00 7D 19 FA D5 12 00 00 00 B0 C2 D1 D6 B0 42 51 D4 00 00 00 00 BC 47 51 D4 | ?x??????}????????????BQ??????GQ?
05-14 14:17:08.281 22707 22707 W leak    :   08 00 00 00 80 17 FA D5 00 00 00 00 | ????????????
05-14 14:17:08.282 22707 22707 W leak    : Leak detected D45147B0 size 22 B for UnicodeString {RefCount: 1} = Self
05-14 14:17:08.283 22707 22707 W leak    : Leak detected D4514A30 size 52 B
05-14 14:17:08.284 22707 22707 W leak    :   F8 79 F1 D5 02 00 00 00 9B 19 FA D5 33 00 00 00 B0 C2 D1 D6 B0 F5 5F D4 00 00 00 00 00 00 00 00 | ?y??????????3?????????_?????????
