TeeTernary.pas Lazarus installation failure
nxuser
Post by nxuser » Wed Apr 12, 2023 8:45 pm
Installing the newest installer into the newest Lazarus/Free Pascal version, I get the following (after a number of other units successfully compile):
Compiling TeeTernary.pas
TeeTernary.pas(284,3) Fatal: Can't find unit LCLT used by TeeTernary
Fatal: Compilation aborted
Error: C:\lazarus\fpc\3.2.2\bin\x86_64-win64\ppcx64.exe returned an error exitcode
Re: TeeTernary.pas Lazarus installation failure
Post by Marc » Tue Apr 18, 2023 12:03 pm
We're checking this. I assume that the previous version of TeeChart didn't generate this error.
Post by Marc » Tue Apr 18, 2023 12:24 pm
Thank you for the problem report. The issue appears to relate to a typo error in the uses of the unit. It has been corrected in current code for the next update release.
If you have the sourcecode you can correct the error here:
TeeTernary.pas, lines 279+
  {$IFDEF LCL}
  LCLT, TeEngineype,
  {$ENDIF}
change to:
  {$IFDEF LCL}
  LCLType,
  {$ENDIF}
nxuser
Post by nxuser » Wed Apr 19, 2023 1:31 am
thanks!
