Problem recompiling FMX packages with TeeRecompile.exe
joabeck
Post by joabeck » Wed Apr 03, 2024 4:30 pm
we bought the Teechart standard source code.
I installed it in a folder and tried to recompile with TeeRecompile.exe.
For VCL packages all works well.
If i choose to recompile FMX packages i get the following error message:
C:\Users\jb\Documents\Delphi Projekte\Delphi-Libs\Steema\TeeChart_Std_2023.39\SourceStandard\FMX_XE6\FMXTee.Editor.Series.ActivityGauge.fmx
to
C:\Users\jb\Documents\Delphi Projekte\Delphi-Libs\Steema\TeeChart_Std_2023.39\SourceStandard\FMX\FMXTee.Editor.Series.ActivityGauge.fmx
Error Code: 2 Description: Das System kann die angegebene Datei nicht finden (cannot find file)
This message is correct, the file "FMXTee.Editor.Series.ActivityGauge.fmx" does not exist in the sub folder ....\FMX_XE6.
I can find in sub folder ....\FMX_XE35.
This happens for all IDEs i can test: XE7 Delphi10.0 and Delphi12.
What is wrong here?
Thank you for your support.
Joachim
Re: Problem recompiling FMX packages with TeeRecompile.exe
Post by Yeray » Thu Apr 04, 2024 6:17 am
I think there was a bug in TeeRecompile.
Could you please give a try at the version here?
joabeck
Post by joabeck » Mon Apr 08, 2024 8:26 am
Thank for the new version of TeeRecompile.
Now it works.
Best Regards
Joachim
