I've a problem to export from VCL to HTML JScript.
When I don't use automatique increment, the labels of Bottom Axis are not visible.
You can find the application in attachement.
Is there a common code between VCL Export HTML5 JSCript and JSCript component?
Export as HTML5 JScript
- ExportHtml5.zip
- (53.1 KiB) Downloaded 1098 times
Re: Export as HTML5 JScript
I could reproduce the problem, so I added a ticket in the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1630
I also fixed it for the next maintenance release.
Since you own the sources, you can apply the fix by changing the following lines in the EmitAxis method in TeeJavaScript.pas:
For these:
Also note in your bottom axis I see you've set DateTimeFormat as 'dd/MM/yyyy HH:MM' but the character to represent minutes is "n" in delphi, while "m" is used for months (reference here). So I'd change it for this:
procedure EmitAxis(Tag:String; const Axis:TChartAxis);
if not TChartAccess(Chart).CalcIsAxisVisible(Axis) then
Exit;
if Minify then NewLocalVar(Tag);
AddScript(Tag+'.visible='+ToBool(False)+';');
if Axis.Inverted then
AddScript(Tag+'.inverted='+ToBool(True)+';');
if Axis.Logarithmic then
AddScript(Tag+'.log='+ToBool(True)+';');
if Axis.Increment<>0 then
AddScript(Tag+'.increment='+FloatToStr(Axis.Increment)+';');
var tmpS: string;
Exit;
if Axis.IsDateTime then
AddScript(Tag+'.increment='+FloatToStr(86400000*Axis.Increment)+';')
tmpS:=LowerCase(Axis.DateTimeFormat);
tmpS:=StringReplace(tmpS, 'n', 'M', [rfReplaceAll]);
AddScript(Tag+'.labels.dateFormat="'+tmpS+'";');
Chart1.Axes.Bottom.DateTimeFormat:='dd/MM/yyyy HH:nn';
thank you very much for the patch!
It works better now!
Would-it possible like in vcl chart to limit automaticaly the number of legend displayed?
- ChartWeb.png (43.18 KiB) Viewed 16141 times
- ChartVcl.png (13.84 KiB) Viewed 16142 times
There may be some difference on how both versions handle the increment in the axis. Could you please arrange a simple example project we can run as-is to reproduce the problem here?
This seems to be the bottom axis labels, not the legend.Menant.D wrote:Would-it possible like in vcl chart to limit automaticaly the number of legend displayed?
You're right, it concern labels of bottom Axe.
The difference is where we put an increment(one day for example) in automatic increment.
You can see it in the project join.
- ExportHtml5_2.zip
- (56.84 KiB) Downloaded 1079 times
This is because the increment property in TeeChart HTML5 is a bit different than in TeeChart VCL.
http://bugs.teechart.net/show_bug.cgi?id=1632
