Gradients and colorEachPoint
Jim Green
Post by Jim Green » Wed Jul 02, 2014 8:07 pm
Hi, when a bar series has a single color gradient it shows fine. When the series shows colors that go from green to yellow to red, the 2nd gradient color on all bars is red (I assume since that is the color of the last bar shown). Can a pair of gradient colors be specified for each point?
Note that the chart definition is coming from VCL TeeSaveToJavascriptFile. Even in the VCL version this was awkward to do, requiring a GetBarStyle to supply the 2nd gradient color.
Jim
Re: Gradients and colorEachPoint
Post by Yeray » Thu Jul 03, 2014 2:10 pm
Hi Jim,
In TeeChart Javascript it's easier to redefine some of the functions. Take a look at this example:
  bar1 = Chart1.addSeries(new Tee.Bar()).addRandom();
  bar1.getFill=function(index,f) {
    var gr=this.format.gradient;
    switch (index) {
      case 0:
        gr.colors=["silver", "red", "white"];
        gr.stops = [0, 0.25, 1];
        break;
      case 1:
        gr.colors=["green", "white", "black"];
        gr.stops = [0, 0.75, 1];
        break;
      default:
        gr.colors=["red", "silver", "yellow"];
        gr.stops = [0, 0.50, 1];
        break;
    return null;
  Chart1.draw();
If getFill() doesn't return null, then all the gradient colors except the first are set to be the color returned by getFill()
However, you can also redefine setEndColor to correct this. Ie:
    switch (index) {
      case 0:
        break;
      case 1:
        break;
      default:
        break;
    return gr.colors[gr.colors.length-1];
  bar1.format.gradient.setEndColor=function(color) {
    var l=this.colors.length;
    if (color && (color!=="") && l>0)
      this.colors[l-1]=color;
Jim Green
Post by Jim Green » Fri Jul 04, 2014 5:44 pm
Thanks Yeray, looks like there's a lot of control possible. (I could never have figured this out myself from the docs though.)
We also uses patterns in the bars sometimes, in addition to the gradients. Can this be done?
Post by Yeray » Tue Jul 08, 2014 11:37 am
The patterns work fine for the Area series as you can see in the Smooth Areas example.
However, I'm afraid I can't find an easy override for the patterns to work with the Bar series.
http://bugs.teechart.net/show_bug.cgi?id=831
Jim Green
Post by Jim Green » Wed Jul 09, 2014 2:32 pm
Thanks. I'll look for some alternatives to patterns (wasn't wild about them anyway).
