SideAll and Labels
Microsolutions
SideAll and Labels
Post by Microsolutions » Thu May 12, 2016 3:14 pm
please check the following code:
<!DOCTYPE html>
<head>
<title>SideAll</title>
<script type="text/javascript" src="https://www.steema.com/files/public/teechart/html5/latest/src/teechart.js"></script>
<script type="text/javascript">
function draw() {
	Chart1=new Tee.Chart("Canvas1");
	var Series1=Chart1.addSeries(new Tee.Bar());
	Series1.format.fill="#90F090";
	Series1.data.values=[288];
	Series1.data.x=[0];
	Series1.data.labels=["Label1"];
	Series1.stacked="sideAll";
	var Series2=Chart1.addSeries(new Tee.Bar());
	Series2.format.fill="#F09090";
	Series2.data.values=[144];
	Series2.data.x=[1];
	Series2.data.labels=["Label2"];
	Series2.stacked="sideAll";
	var Series3=Chart1.addSeries(new Tee.Bar());
	Series3.format.fill="#9090F0";
	Series3.data.values=[72];
	Series3.data.x=[2];
	Series3.data.labels=["Label3"];
	Series3.stacked="sideAll";
	Chart1.draw();
</script>
</HEAD>
<BODY onload="draw()">
<canvas id="Canvas1" width="800" height="600">
</canvas>
</BODY>
</HTML>
Compared to the VCL version of the TeeChart:
- the width of the bars should be the same,
- only the first label is visible.
Check it, please.
Thanks in advance,
MS
Re: SideAll and Labels
Post by Yeray » Fri May 13, 2016 2:33 pm
Microsolutions wrote:- the width of the bars should be the same,
http://bugs.teechart.net/show_bug.cgi?id=1541
Microsolutions wrote:- only the first label is visible.
http://bugs.teechart.net/show_bug.cgi?id=1542
I'm not sure if it's feasible in your real application, but in this simple example you could use a single series with three values.
Microsolutions
Post by Microsolutions » Fri May 13, 2016 5:50 pm
of course I use it with more values, I just tried to make the example as simle as possible.
Thanks for creating the bugreports.
Best regards,
MS
Microsolutions
Post by Microsolutions » Fri Jun 03, 2016 2:52 pm
when can we expect the fixed JS version?
Best regards,
MS
Post by Yeray » Fri Jun 10, 2016 2:44 pm
We've fixed both problems so we closed both tickets.
I'll send you a mail with the latest version of the teechart.js so you can test it.
