Piechart - percentage value display based on multi language
SenSeo
Post by SenSeo » Thu Aug 11, 2016 4:54 pm
We have created a pie chart and decimal values are assigned to pie chart for chart generation . The problem is that the decimal number format is not changed when I switch from one language to another language. For example the value should change and display on segment from 4.5 to 4,5(German language)
chart1.data.values = [a1, a2, a3];
chart1.data.labels = [a1.toLocaleString(), a2.toLocaleString(), a3.toLocaleString()];
Also the label value is not changed based on language setting. I used javascript function "toLocalString()" for formatting decimal/number values based on culture.
Is there any way to format the number and display it on chart based on multilanguage?
Re: Piechart - percentage value display based on multi language
Post by Marc » Mon Aug 22, 2016 11:57 am
We're just checking to offer an improvement here. TeeChart does a toFixed() decimal length on display values. ToFixed is not compatible with LocaleString (that doesn't respect the decimal places). I'll get back to this thread.
Post by Yeray » Tue Aug 23, 2016 10:53 am
Just for reference, note I've just posted a workaround to this issue here:
http://www.teechart.net/support/viewtop ... 081#p72081
